Dear all,
I have a question about Daysim and Gendaylit.
I`m simulating a simple room to link the lighting performance to
thermal ones and to do it i`m using Daysim and gendaylit.
I add into Daysim the Direct Normal Radiation and the Diffuse
Horizontal Radiation from epw file (London).
Then I lunched the simulation in Daysim only with an external sensor
point, first simulation with no bounces and then with ab= 4 and I got
Direct and Global Horizontal hourly illuminance values (Lux) and
Irradiance values (W/mq)
The parameters used to do it are:
-ab 4 -ad 1024 -as 256 -ar 512 -aa 0.1 -lr 2 -st 0.015 -sj 1 -lw
0.004 -dj 0.5 -ds 0.001 -dr 2 -dp 512
Check: there are little difference (1-2%) about Horizontal DIffuse
and Direct Irradiance and during sunrise and sunset this difference is
about 5% for Direect Irrradiance.
Then I created a sky by gendaylit (Radiance) for 3 hours (9:30, 12:
30, 15:30) and for three days (21 March, 21 June and 21 December),
adding the hourly irradiance values from epw, to check the difference
to illuminace provided by Gendaylit (Radiance) and Daysim by means of a
external sensor point.
Data values are:
Time Dir Norm Rad Diff Ho Rad
Mar 09:30 420.00 182.00
Mar 12:30 422.00 238.00
Mar 15:30 184.00 167.00
Jun 09:30 425.00 292.00
Jun 12:30 316.00 374.00
Jun 15:30 505.00 222.00
Dec 09:30 162.00 50.00
Dec 12:30 513.00 69.00
Dec 15:30 0.00 10.00
gendaylit $months $days $hours -a 51.5 -o 0 -m 0 -W $direct $diffuse
skies/perez_sky_$months.$days.$hours.rad
Dome.mat
skyfunc glow skyglow
4 1 1 1 0
skyglow source sky
4 0 0 1 180
oconv -w skies/perez_sky_$months.$days.$hours.rad dome.mat >
oct/perez_sky_$months.$days.$hours.oct
rtrace -h- -w- $param -I -opv oct/perez_sky_$months.$days.$hours.oct
< point.grd | rcalc -e '$1=$1; $2=$2; $3=$3; $4=($4*0.265+$5*0.670+$6*0.
065)*179' > result.illum.$months.$days.$hours.rs &
Parameters for rtrace are the same used to generate the sky by
Daysim.
I have found these difference (illuminance):
Time Dir Norm Rad Diff Ho Rad Horiz_Direct Ill (lux)
- Daysim Horiz_Direct Ill (lux) - Gendaylit
18000
18213
24302 24494
6319 6294
30854 31099
26763 26899
31907 31870
Dec 09:30 162.00
50.00
1133 1197
10444 10519
Dec 15:30 0.00
10.00
0 0
Time Dir Norm Rad Diff Ho Rad Horiz_Glob Ill (lux) -
Daysim Horiz_Glob Ill (lux) - Gendaylit
41477 30154
54439 39691
25891 16146
66633 49155
70027 48607
59991 46200
Dec 09:30 162.00
50.00
7539 4463
20718 15751
Dec 15:30 0.00
10.00
1144 597
As you can look at there are important difference in the Horiz
Diffuse Illuminace.
I don`t know if my way is right but I`d like to know something about
it and what sky is better to use to get the horly internal illuminace
values to link these ones to EnergyPlus or Trnsys.
Thanks a lot
Sorry for my personal english.
Roberto
Supera i limiti: raddoppia la velocità da 10 a 20 Mega! Risparmia con Tutto Incluso: telefono + adsl 20 mega a soli 29,95 € al mese per due anni!SCONTO DI 240 EURO!http://abbonati.tiscali.it/telefono-adsl/prodotti/tc/tuttoincluso/?WT.mc_id=01fw
