Daysim and results
Sending this discussion over from Radiance-general, where it was posted inadvertently.
Begin forwarded message:
Subject: [Radiance-general] Daysim and results
Date: September 2, 2015 4:05:35 AM PDT
To: Radiance Radiance <radiance-general@radiance-online.org>
Reply-To: Per Haugaard <perhaugaard@yahoo.dk>, Radiance general discussion <radiance-general@radiance-online.org>
Dear user
Sorry to post my question in this forum, but since it deals with daylight I think that it's ok.
A brief question about Daysim and results.
I have made an analysis of a room where I compare the energy savings for artificial lighting by changing the ceiling reflectance. I look at two types of installed effect - 5 W/m2 and 10 W/m2. which is the only difference between the two calculations. There is no solar shading in the model.
I use the same model for both analyzes. This means that I only make a one calculation of daylight coefficients.
The light is controlled in both analyzes via photo sensors with dimming (photo-sensor control).
The for my question. Why is there a smaller increase in energy consumption of approximately 1 W/m2 by going from 5 W/m2 to 10 W/m2 installed power? Here I compare 2 x the energy consumption for 5 W/m2 with the energy consumption of 10 W/m2
I look forward to hearing from you
Best regards
Per Haugaard
Subject: Re: [Radiance-general] Daysim and results
Date: September 2, 2015 6:01:00 AM PDT
Reply-To: Radiance general discussion <radiance-general@radiance-online.org>
I think that might make sense. Imagine a room that is perfectly well daylit, where you never need to turn the lights on. It will not matter weather you installed 1W/m2 or 100W/m2, the energy consumption will always be 0kWh/m2.
I would expect that, since you doubled the Lighting Power in the room, the energy consumption also doubled. Does that make sense?
Otherwise... I am not quite sure how Daysim works.
Germán
2015-09-02 8:05 GMT-03:00 Per Haugaard <perhaugaard@yahoo.dk>:
Dear user
Best regards
Per Haugaard
Date: September 2, 2015 6:12:43 AM PDT
To: Germán Molina Larrain <germolinal@gmail.com>, Radiance general discussion <radiance-general@radiance-online.org>
Hi Germán,
Thank you for your reply.
The annual energy consumption goes from e.g. 100 kWh/m2 to 108 kWh/m2 when going from an installed lighting power from 5W/m2 to 10 W/m2.
It is the 8% increase I do not quite understand.
Any input is much appreciated.
Best regards
Per Haugaard
Den 15:01 onsdag den 2. september 2015 skrev Germán Molina Larrain <germolinal@gmail.com>:
Germán
Dear user
Best regards
Per Haugaard
Date: September 2, 2015 6:21:02 AM PDT
Cc: Radiance general discussion <radiance-general@radiance-online.org>
mmm... Is one set of luminaires more efficient? or does one of them actually illuminates more?
2015-09-02 10:12 GMT-03:00 Per Haugaard <perhaugaard@yahoo.dk>:
Hi Germán,
Best regards
Per Haugaard
Germán
Dear user
Best regards
Per Haugaard
Date: September 2, 2015 6:44:27 AM PDT
Do you have the lighting control algorithm set to be dimming? If it was switching on and off for the same hours each year in two simulations, the energy use would be double. If the calculation assumes lights are dimmed, the 8% difference is only due to the interpolation difference between the low end energy use (minimum ballast power) and the upper end of the energy use. In other words, maybe you have many hours that daylight provides nearly all of the specified lux requirement, so your lights are always dimmed to a fraction of only 5W/m² or 10W/m² for most of the year at any times they are set to on.
I’m also not sure if your control algorithm might also assume that if you say the 10W/m² provides 600 lux and the 5W/m² provides 300 lux, but your daylight autonomy threshold is set to 300 lux, the calculation may never use the full 10W/m² load. I’m a bit out of practice with Daysim so I can’t recall for sure if either of these scenarios are likely to occur without knowing it.
-Chris
Sent: Wednesday, September 02, 2015 9:13 AM
Dear userSorry to post my question in this forum, but since it deals with daylight I think that it's ok.
A brief question about Daysim and results.I have made an analysis of a room where I compare the energy savings for artificial lighting by changing the ceiling reflectance. I look at two types of installed effect - 5 W/m2 and 10 W/m2. which is the only difference between the two calculations. There is no solar shading in the model.
I use the same model for both analyzes. This means that I only make a one calculation of daylight coefficients. The light is controlled in both analyzes via photo sensors with dimming (photo-sensor control).
Best regards
Per Haugaard
be 0kWh/m2.
Germán
Dear user
model.
Best regards
Per Haugaard
Hi Germán,
Thank you for your reply.The annual energy consumption goes from e.g. 100 kWh/m2 to 108 kWh/m2 when going from an installed lighting power from 5W/m2 to 10 W/m2.It is the 8% increase I do not quite understand.Any input is much appreciated.
Best regards
Per Haugaard
Germán
Best regards
Per Haugaard
Hi Germán,
Best regards
Per Haugaard
be 0kWh/m2.
Germán
Dear user
model.
Best regards
Per Haugaard
-Chris
I sent this discussion to the daysim mailing list, which I think it was intended for originally. Please add responses there.
Also, we might think about posting the question to Unmet Hours.
