I'm trying to run a -dds simulation using Daysim 4, but get the following error when I run gen_dc in -dds mode (gen_dc file.hea -dds)
FATAL ERROR - ds_illum variable DDS_sensor_file not provided in header file
However, I can't find anything in the Daysim documentation that describes the "DDS_sensor_file" keyword / behaviour. I have successfully run this same header file in regular mode and I would have thought the sensor file should be the same.
Is there anywhere I can find this behaviour?
Reinier Zeldenrust
Environmental Designer
Atelier Ten
Environmental Design Consultants + Building Services Engineers
CIBSE Building Services Consultancy of the Year 2011
UK-GBC Sustainability Consultant of the Year 2009
Hi Reinier,
As far as I can recall, you don't need to create the DDS sensor file yourself, but only add the following entries into the .hea file.
*DDS_sensor_file* test.dds
*DDS_file* test.sen
Alstan
On 3/11/2015 7:57 PM, Reinier Zeldenrust wrote:
I�m trying to run a �dds simulation using Daysim 4, but get the following error when I run gen_dc in �dds mode (gen_dc file.hea �dds)
FATAL ERROR � ds_illum variable DDS_sensor_file not provided in header file
However, I can�t find anything in the Daysim documentation that describes the �DDS_sensor_file� keyword / behaviour. I have successfully run this same header file in regular mode and I would have thought the sensor file should be the same.
Reinier Zeldenrust
Atelier Ten
Radiance-daysim mailing list
Radiance-daysim@radiance-online.org
Thanks Alstan, that is correct the *.sen files came from an idea Denis Bourgeois and I conceptualized (but never fully used) to store additional info with each sensor in an XML file. This can be largely ignored.
Christoph
From: J. Alstan Jakubiec [mailto:alstan@jakubiec.net]
Sent: Wednesday, March 11, 2015 7:20 PM
To: radiance-daysim@radiance-online.org
Subject: Re: [Radiance-daysim] Daysim 4 -dds mode
Hi Reinier,
DDS_sensor_file test.dds
DDS_file test.sen
Alstan
Reinier Zeldenrust
Atelier Ten
Radiance-daysim@radiance-online.org<mailto:Radiance-daysim@radiance-online.org>
Thank you both - it works now!
Kind regards,
Reinier Zeldenrust
Atelier Ten
Sent: 12 March 2015 00:00
To: DAYSIM discussion
Christoph
To: radiance-daysim@radiance-online.org<mailto:radiance-daysim@radiance-online.org>
Hi Reinier,
DDS_file test.sen
Alstan
Reinier Zeldenrust
Atelier Ten
