Daylight Simulation
As part of my master's thesis, I am doing only interior Daylight
simualtion. No luminares are defined.The runs are solely daylight. I am
using an already built space. The location used is Dubai (United Arab
Emirates), and because this location is not available I had to define it.
Although I had all the required parameters, when I do the runs the results
does not seem to change, and to check it out correctly I tried to do the
runs during night times, around 10 pm and to my surprise I had light in
the space.
Could anyone help..
Thank you,
Maitha Dalmouk
Is the -av parameter not zero?
Martin Moeck
From: radiance-general-bounces@radiance-online.org on behalf of Maitha Dalmouk Al-Nuaimi
Sent: Mon 4/24/2006 4:08 PM
To: Radiance-general@radiance-online.org
Subject: [Radiance-general] Daylight Simulation
the space.
Could anyone help..
Thank you,
Maitha Dalmouk
Perhaps your -av setting is too high.
From: "Maitha Dalmouk Al-Nuaimi" <m.dalmouk@tamu.edu>
Date: April 24, 2006 1:08:09 PM PDT
the space.
Could anyone help..
Thank you,
Maitha Dalmouk
Is that the ambient value? if so it is blank. should I change that??
Maitha
Martin Moeck
Dalmouk Al-Nuaimi
the space.
Could anyone help..
Thank you,
Maitha Dalmouk
Yes, use -av 0 0 0
Sent: Mon 4/24/2006 6:11 PM
Subject: RE: [Radiance-general] Daylight Simulation
Maitha
Martin Moeck
Dalmouk Al-Nuaimi
the space.
Could anyone help..
Thank you,
Maitha Dalmouk
can you send an example of
- how you create the sky distribution and
- how yoy call the rpict tool?
Do you use rpict by calling it manually, do you use a script?
CU Lars.
