Crop HDRIs in radiance and evalglare
Dear list,
I am trying to glare analysis via HDR images captured by a canon DSLR Camera and sigma fish eye lens.
The procedure that I use was
1. Taking 13 images via gphoto2 +Crontab
2. Creating HDR images in HDRgen
3. Resize
pfilt -x 1433 -y 955 Big.hdr > resize.hdr
4.Crop & cleaning mask
ra_xyze -r -o -u resize.hdr | pcompos -x 800 -y 800 - -315 -78 > crop.hdr | pcomb -s -1000 output_masked2.hdr
5. Evalglare analysis
echo "VIEW= -vta -vh 180 -vv 180 -vp 0 0 0 -vd 1 0 0 -vu 0 0 1" > output_masked2.hdr
evalglare output_masked2.hdr
The problem is that Evalglare reports errors after the crop process.
error: no valid view specified
(There was no evalglare errors when I test it with the resized image.)
I has checked the luminance values of the HDR in photosphere and it looks OK!
Do I need to use another crop command for evalglare processing?
Please, let me know if you have any ideas.
Best regards,
Jonghoon Kim
Ph.D. student
Texas A&M University
Both pcompos and pcomb mess with the HDR header. Also, what you are doing here:
output_masked2.hdr
is overwrite HDR image output_masked2.hdr with just the view string.
You need to edit this image in a text editor and put a full VIEW= line
back in. If you're happy using vim, then you could try Radiance's
vinfo.
Regards
Axel
On 26 February 2014 15:33, Jonghoon Kim <[email protected]> wrote:
Dear list,
3. Resize
output_masked2.hdr
OK!
Best regards,
Jonghoon Kim
Ph.D. student
HDRI mailing list
Hi Kim,
Comments in-line below...
I appreciate your comment Axel!!
I slightly modified my code and it is working now.
However, I have one more question!
My HDR process is like below.
(Please, let me know if there is something wrong in my script.)
Cropping the original HDR image to match the size with the vignetting
filter file
ra_xyze -r -o -u Original.hdr | pcompos -x 4368 -y 2912 - -408 -272 >
Resized_for_Vignetting.hdr
You don't need the ra_xyze -r here.
If you're using a fisheye lens, then I'm not sure why the -x and -y of pcompose are not the same. Does this have to do with your vignetting filter?
Applying the vignetting filter to the cropped HDRI
pcomb -e 'ro=ri(1) / ri(2);go=gi(1) / gi(2);bo=bi(1) / bi(2)'
Resized_for_Vignetting.hdr Vignetting_Filter.hdr > Vignetting_Corrected.hdr
Resizing the HDRI for glare analysis
pfilt -x 1200 -y 800 Vignetting_Corrected.hdr >
Vignetting_Corrected_resized.hdr
Deriving glare metrics from a resized HDR images gives you somewhat different values compared to getting them off the original, larger-res image. You might want to test this, and see how large the differences in UGR, DGP etc are.
Cropping the HDRI for glare analysis
ra_xyze -r -o -u Vignetting_Corrected_resized.hdr | pcompos -x 800 -y
800 - -200 0 > Cropped.hdr
Oh, so now you're cropping it into a square.
Creating the cleaning filter
ra_tiff -r Cleaning_filter.tif Cleaning_filter.hdr
Is this cleaning filter for removing hot or dead pixels?
Applying the cleaning filter on the resized HDRI
pcomb Cropped.hdr -s -1000 Cleaning_filter.hdr > Final.hdr
Running the Evalglare analysis
evalglare -vta -vh 180 -vv 180 Final.hdr
You can streamline this a little:
a) crop and square and make the border black:
dim=1234 # or whatever the diameter (in pixels) of the actual fisheye on your large-size HDR
pcompos -x $dim -y $dim hdrgen.hdr -$xoffset -$yoffset \
pcomb -e
's(x):x*x;m=if(xmax*ymax/4-s(x-xmax/2)-s(y-ymax/2),1,0);ro=m*ri(1);go=m*gi(1);bo=m*bi(1)' \
- |pfilt > tidy.hdr
b) do some QA
By the sounds of it, you're working under LINUX. I suggest you check out webhdrtools. This is some of the magic behind the WebHDR site, packaged as individual Perl scripts.
http://www.jaloxa.eu/resources/hdr/webhdrtools
Before you move on to deriving the actual glare metrics, I suggest you
b1) verify that the dynamic range that you've captured within your sequence is sufficient. Use webhdr_jpgheatmap.pl for this. If there are any red pixels on the heatmap, the sequence is not usable for glare stuff.
b2) verify that the recovered RSP is good. webhdr_rspplot.pl helps you plot it (relies on gnuplot). The red, grn, and blu curve should be almost identical, and there should be no weird wobbles. It might be best to take a number of calibration HDRs, and to derive an averaged RSP from them. webhdr_rspavrg.pl is your friend here.
c) fix the view
I have a tool that does this, but since it hasn't been tested properly, I have not included it in the webhdrtools yet. You might want to give it a try, and see if it works for you:
http://www.jaloxa.eu/pickup/webhdr_hdrcalib.pl
Run it like so:
STDVIEW="-vta -vp 0 0 0 -vd 0 1 0 -vu 0 0 1 -vv 180 -vh 180"
CF=1.0 # Your calibration factor.
# See Camera Calibration
webhdr_hdrcalib.pl $STDVIEW -m $CF tidy.hdr > tidy_fixed.hdr
webhdr_hdrcalib.pl also has a -f option that will attempt to recover a view that exists in the HDR header, but got corrupted by pcomb or pcompos. However, for images generated by hdrgen, it's best to not do this, since hdrgen relies on the EXIF info from the photographs that don't always give you accurate view angles.
d) do your glare stuff...
Done. Now have a cup of tea and flick through my "Glare measurement using HDR photography" presentation from the 2012 Radiance workshop:
http://radiance-online.org/community/workshops/2012-copenhagen
I hope you're not trying to measure glare from LED light sources...
Regards
Axel
On 27/02/14 15:55, Jonghoon Kim wrote:
After the process above, The header file is like below.
#?RADIANCE
CAPDATE= 2014:02:26 22:58:34
GMT= 2014:02:27 04:58:34
/Users/jonghoonkim/Desktop/Sample HDRI/Crop800_800.hdr:
CAPDATE= 2014:02:26 22:51:52
GMT= 2014:02:27 04:51:52
<stdin>:
CAPDATE= 2014:02:26 22:16:03
GMT= 2014:02:27 04:16:03
/Users/jonghoonkim/Desktop/Sample HDRI/Big_for_Vignetting.hdr:
CAPDATE= 2014:02:26 22:09:29
GMT= 2014:02:27 04:09:29
<stdin>:
CAMERA= Canon Canon EOS 60D version v.0
Photosphere created HDR image from 'Jong_-2014-0111-1104-14.jpg'
'Jong_-2014-0111-1104-17.jpg' 'Jong_-2014-0111-1104-20.jpg'
'Jong_-2014-0111-1104-22.jpg' 'Jong_-2014-0111-1104-25.jpg'
'Jong_-2014-0111-1104-28.jpg' 'Jong_-2014-0111-1104-31.jpg'
'Jong_-2014-0111-1104-34.jpg' 'Jong_-2014-0111-1104-37.jpg'
'Jong_-2014-0111-1104-40.jpg' 'Jong_-2014-0111-1104-44.jpg'
'Jong_-2014-0111-1104-48.jpg' 'Jong_-2014-0111-1104-53.jpg'
VIEW= -vtv -vh 132.979172 -vv 113.747666
CAPDATE= 2014:01:11 12:05:53
ra_xyze -r -o -u "/Users/jonghoonkim/Desktop/Sample HDRI/Big.hdr"
PRIMARIES= 0.6400 0.3300 0.2900 0.6000 0.1500 0.0600 0.3333 0.3333
/Users/jonghoonkim/Desktop/Sample HDRI/Sigma_f56FishVigL.hdr:
# Output from HDRShop
EXPOSURE= 1.0000000000000
pcomb -e "ro=ri(1) / ri(2);go=gi(1) / gi(2);bo=bi(1) / bi(2)"
"/Users/jonghoonkim/Desktop/Sample HDRI/Big_for_Vignetting.hdr"
"/Users/jonghoonkim/Desktop/Sample HDRI/Sigma_f56FishVigL.hdr"
ra_xyze -r -o -u "/Users/jonghoonkim/Desktop/Sample HDRI/Resize.hdr"
pcompos -x 800 -y 800 - -200 0
/Users/jonghoonkim/Desktop/Sample HDRI/Cleaning_filter.hdr:
ra_tiff -r
CAPDATE= 2014:02:25 16:15:37
pcomb "/Users/jonghoonkim/Desktop/Sample HDRI/Crop800_800.hdr" -s -1000
"/Users/jonghoonkim/Desktop/Sample HDRI/Cleaning_filter.hdr"
FORMAT=32-bit_rle_rgbe
The header file is very long like above after the whole process.
I could run evalglare with the final.hdr. ( It looks OK until now.)
Is the header file is OK for futhur HDRI analysis?
Are there any potential error source in the head?
If I need to modify the head, can you explain a little bit more on vim
and Radiance�s info?
