I was experimenting with rtrace -n option and I would like to create
irradiance image of the building workplane for DF analysis.
As Greg mentioned on Workshop, rtrace -n doesn't work well with -x option,
because after every line values are flushed.
It means that output image would have lines-like patterns (because no
cashing between lines, for various rtrace processes).
So question is for Greg, but I think answer can be interesting for list
users:
Is there some other way to get proper image with rtrace running in multiple
processes.
For the moment I'm using command line like this:
rtrace *-n 4 *-ab 5 -ad 1024 -as 512 -aa 0.1 -av 0 0 0 -ar 300 -h+ -I+ -ov
-fac *-x 1024 *-y 448 octree.oct < points.txt > image.hdr
and resulting image has lines-like artifacts.
Thanks in advance,
Marija.
Hi Marija.
I haven't tried this but you should be able to specify four separate
rtrace processes where each renders a subimage of your workplane.
If you want a perspective view you can use the "-vs" and "-vl"
options to get a continuous perspective.
On Wed, Oct 13, 2010 at 7:21 AM, Marija Velickovic <[email protected]> wrote:
users:
processes.
rtrace -n 4 -ab 5 -ad 1024 -as 512 -aa 0.1 -av 0 0 0 -ar 300 -h+ -I+ -ov
-fac -x 1024 -y 448 octree.oct < points.txt > image.hdr
Thanks in advance,
Marija.
Hi Marija,
In the latest HEAD, I have changed the behavior of rtrace so if -x is anything but 1 and -y is non-zero as well, ray flushing does not take place. It was really a performance issue rather than an issue with artifacts, however. You should get acceptable results with the 4.0 release.
I can only suppose that you are seeing lines in your example because you are not sharing the irradiance cache between processes. I recommend you add a -af option to do so. Also, it may indicate that your -ad parameter needs to be a little larger.
I hope this helps.
Date: October 13, 2010 5:21:52 AM PDT
I was experimenting with rtrace -n option and I would like to create irradiance image of the building workplane for DF analysis.
As Greg mentioned on Workshop, rtrace -n doesn't work well with -x option, because after every line values are flushed.
It means that output image would have lines-like patterns (because no cashing between lines, for various rtrace processes).
So question is for Greg, but I think answer can be interesting for list users:
Is there some other way to get proper image with rtrace running in multiple processes.
rtrace -n 4 -ab 5 -ad 1024 -as 512 -aa 0.1 -av 0 0 0 -ar 300 -h+ -I+ -ov -fac -x 1024 -y 448 octree.oct < points.txt > image.hdr
Thanks in advance,
Marija.
