Dear All,
Best wishes for a happy 2022. I am simulating a room with some ceiling-sensors and some workplane points (no shield) by using three-phase method and rsensor (with a custom sensitivity distribution). I think my simulation is different to the simulation in three-phase method tutorials (for example: Sarith’s one) at creating a view matrix. This is the Sarith’s command for creating a view matrix:
rfluxmtx -v -I+ -ab 4 -ad 5000 -lw 0.0002 -n 16 -y 100 - objects/GlazingVmtx.rad
-i octrees/room3ph.oct < points.txt > matrices/vmtx/v.mtx
The file points.txt is only for workplane points. I need to add some sensor views with a custom sensitivity distribution. This is a command I found in this forum to create a view matrix with rsensor:
rsensor -h -rd 5000 -vf view_test.vf narrow10.dat . |rcontrib -c 5000 -f klems_int.cal -bn Nkbins -b kbinS -m glazing -I+ -ab 11 -ad 50000 -ds .1 -lw 1e-5 test_r.oct>narrow10.vmx
And the commands for running multiple ceiling-sensors:
rcalc -o 'rsensor -h -rd 10000 -vp ${$1} ${$2} ${$3} -vd ${$4} ${$5} ${$6} sensor.dat .' posdir.txt
| sh
| rtrace -n 8 -af calc.cache [rtrace options] -h -ov octree
| total -10000 -m
| rlam posdir.txt -
| rcalc -e ‘$1=$1;$2=$2;$3=$3;$4=179*(.265*$7+.670*$8+.065*$9)’
So I will need to combine rfluxmtx with rsensor and rcalc in order to create a view matrix for three-phase method. Could you give me some advice for their combination?
Thanks in advance,
Cong
