correction for barrel distortion
Assume you have a barrel distortion image like the one shown at
http://www.dcresource.com/reviews/nikon/coolpix5400-review/
towards the bottom of the page.
1) Are there software tools or algorithms available to correct these images before they are converted into an HDR image?
2) If not, is there a simple way to correct the HDR image for barrel distortion?
Martin Moeck
Martin,
Photoshop CS2 has a Lens Correction filter that will help correct chromatic aberration, vignetting and barrel/pincushion distortion.
Lens Correction
However, I opened a HDR image (*.hdr) and the Filter>Distortion menu option was not available, leading me to believe that it will not operate directly on HDR 32 bit images. Thus, it would seem that you would apply it to your LDR sequence images before converting to a HDR image. The filter permits the applied settings to be saved, so you could open one image, applying the correction and then save the settings for the subsequent application to the rest of the image sequence, permitting automation in a batch action. If your sequence is taken with a tripod and the images are registered prior to correction, I would guess that applying the same correction through saved settings should displace the same pixels in each image and preserve image registration.
I just upgraded to CS2 so I haven't played with it yet.
kirk
Martin Moeck
Hdri mailing list
I could be wrong, but don't HDR creators need the original camera shot with
exif information? Doing Photoshop adjustments would lose that info. I'm
pretty sure Photosphere needs this, but I don't know if HDRShop does.
Rob F
Sent: Tuesday, January 17, 2006 9:03 AM
Subject: Re: [Hdri] correction for barrel distortion
Martin,
Lens Correction
registration.
kirk
<http://www.dcresource.com/reviews/nikon/coolpix5400-review/&gt;
distortion?
Martin Moeck
Hdri mailing list
[email protected] <http://www.radiance-online.org>
<http://www.radiance-online.org/mailman/listinfo/hdri&gt;
Hi Rob - FWIW, I've never had a problem with Photoshop stripping this info - EXIF is kept intact. Good point to consider though.
Kirk L. Thibault, Ph.D.
p. 215.271.7720
f. 215.271.7740
c. 267.918.6908
skype. kirkthibault
On Jan 17, 2006, at 1:38 PM, Fitzsimmons, Rob wrote:
I could be wrong, but don't HDR creators need the original camera shot with exif information? Doing Photoshop adjustments would lose that info. I'm pretty sure Photosphere needs this, but I don't know if HDRShop does.
Rob F
Martin,
Photoshop CS2 has a Lens Correction filter that will help correct chromatic aberration, vignetting and barrel/pincushion distortion. >>Lens Correction
kirk
Martin Moeck
Hdri mailing list
Hdri mailing list
I suppose that if you alter the image, the EXIF info will be wiped.
p. 215.271.7720
f. 215.271.7740
c. 267.918.6908
skype. kirkthibault
Rob F
Martin,
kirk
Martin Moeck
Hdri mailing list
Hdri mailing list
HDRShop will permit you to manually specify the exposure increment between each image in a LDR sequence.
p. 215.271.7720
f. 215.271.7740
c. 267.918.6908
skype. kirkthibault
Rob F
Martin,
kirk
Martin Moeck
Hdri mailing list
Hdri mailing list
No luck with Photoshop lens corrections. This is like poor freehand drawing. All gridlines are not vertical or horizontal, but warped in interesting ways.
Each square with barrel distortion has to be corrected individually. Greg needs to do take care of this right now :slight_smile: This community needs a tool to shift pixels in a Radiance image around. Input could be a black and white grid image showing the barrel distortion. Output would be the image with straight lines.
Greg, I can help you with the command line :slight_smile: :
pcomb -f barrel.cal barrelgrid.pic original.hdr > corrected.hdr
See, Greg, we are already halfway there :slight_smile:
Martin
Sent: Tue 1/17/2006 3:52 PM
p. 215.271.7720
f. 215.271.7740
c. 267.918.6908
skype. kirkthibault
  Rob F
    Martin,
    Photoshop CS2 has a Lens Correction filter that will help correct chromatic aberration, vignetting and barrel/pincushion distortion. Filter>Distortion>Lens Correction
    kirk
      Martin Moeck
      Hdri mailing list
  Hdri mailing list
Has anyone tried "LensFix & PanoTools Plug-ins for OSX" ?
I haven't had much of a chance to try it but have heard good things about it.
I have a product description if that is of use.
Paul
Martin
p. 215.271.7720
f. 215.271.7740
c. 267.918.6908
skype. kirkthibault
Rob F
Martin,
kirk
Martin Moeck
Hdri mailing list
http://www.radiance-online.org/mailman/listinfo/hdri_______________________________________________
Hdri mailing list
Hdri mailing list
Haha. Very funny, indeed!
I just tried the lens warp with Photoshop CS2 on my Mac, and it did preserve the Exif information, so I think that process could work.
Pcomb does support limited filtering, which could include some warping, but you have to keep the scans within 32 pixels of each other (or so), and that might be a problem. You would also want to implement a bicubic filter, I suppose.
Date: January 17, 2006 1:40:26 PM PST
Martin
The GIMP image manipulation package is available for OSX, and there are a
number of interesting plug-ins, including barrel distortion. Dunno if the
EXIF info is kept, but if not, you may just save it to a text file and
re-create an appropriate EXIF header once the dirty jobs are done.
There is also Hugin, a tool for stitiching panoramas. See here:
http://hugin.sourceforge.net/tutorials/perspective/en.shtml
how you can use it to correct barrel distortion. This is kinda
extreme-unbarrelling, though...
Axel
..., and see down at the bottom of this page:
for more distortion correcting software. There is a Photoshop plug-in, too
Axel
Sorry--link included now
http://www.panotools.info/mediawiki/index.php?title=Lens_correction_model
Axel
Axel
