converting unfinished renderings
Hi All,
I have acces to a rendering computer via putty - no X11, so I can not see the status of renderings using ximage. When I try to convert the rendering I get the obvious "errror reading Radiance picture" error. Does anybody has a workaround for this situation? In other words, is there any way to convert an unfinished rendering?
-Iebele
I've found that "ra_ppm file.pic > file.pnm" gives me an image with black in the unfinished portions. Trying to add pnmtopng as a pipe just returns a 0-length file, but using a two-step method with ppm as an intermediary works.
Mark
On Fri, 23 May 2008, iebele wrote:
Hi All,
-Iebele
I believe pfilt can also take in a partial image.
[mailto:[email protected]] On Behalf Of Mark
Stock
Sent: Friday, 23 May, 2008 5:58 PM
To: [email protected]; Radiance general discussion
Subject: Re: [Radiance-general] converting unfinished renderings
Mark
Hi All,
see the
rendering I get
a
convert an
-Iebele
Hi Mark, Christopher,
Using pfilt and adding ximage to the pipe works fine, if I had X on my system...
Ra_ppm and even ra_t16 converted unifinished renderings with succes in earlier days. These days I get an error.
Did you use "ra_ppm file.pic > file.pnm" on a recent distribution?
Iebele
Stock
Mark
Hi All,
see the
rendering I get
a
convert an
-Iebele
Hi Iebele,
Just pipe pfilt -2 into ra_whatever and do it that way. Pfilt is the only program officially designed to accept incomplete Radiance renderings. Everything else will generate an error.
Date: May 24, 2008 11:10:41 AM PDT
Iebele
ra_ppm returns an error, but I still get a full-resolution, albeit partially black, image using ra_ppm from "rpict -version" -> "RADIANCE 4.0a".
Mark
On Sat, 24 May 2008, Greg Ward wrote:
Hi Iebele,
Iebele
