converting RGB value to illuminance
Hello
I am using a 4.5 mm fisheye lens to take HDR image. I was wondering if there is a way to convert RGB value to illuminance (lux). I would say I need to have the reflectance of the material but I don't know how to apply it to these per pixel value. Any help is appreciated. Thanks. Farzaneh
Hi Farzaneh,
the integral of the entire image, if it covers one hemisphere, would equal to the illuminance at the entrance pupil of your lens. However, I guess that you are more interested in relating pixel values to the illuminance at the corresponding locations on the reflective surfaces. For that, you could approximate the illuminance from luminance (what is what you camera measures, if it is properly calibrated), as long as you can assume the surface to be perfectly diffuse. This introduces errors, but may give some reasonable idea at least if you pick only appropriate surfaces without strong specular / glossy reflection.
You may want to go through John's slides from last year's Radiance workshop: https://www.radiance-online.org/community/workshops/2016-padua/presentations/202-Mardaljevic-DaylightInHeritageSpaces.pdf
We also presented a method employing markers some time ago: Multi-point simultaneous illuminance measurement with high dynamic range photography
Lars.
Hello
I am using a 4.5 mm fisheye lens to take HDR image. I was wondering if there is a way to convert RGB value to illuminance (lux). I would say I need to have the reflectance of the material but I don�t know how to apply it to these per pixel value. Any help is appreciated. Thanks. Farzaneh
