compiling RTcontrib
RTcontrib was the final argument i needed to put myself together and
install linux.
Got the ubuntu distro & i'm up an running. Oh, the joy of compiling
the HEAD release.
Really, i have to admit, i thought compiling software would do me in,
but its really not That Tough... Ok i'll stop the
initial-over-confidence here...
thing is although compiling seems to do well, the initial reason for
getting into this exercise seems to be not so willing:
rtcontrib.c: In function `killpersist':
rtcontrib.c:299: error: `SIGALRM' undeclared (first use in this function)
rtcontrib.c:299: error: (Each undeclared identifier is reported only once
rtcontrib.c:299: error: for each function it appears in.)
rtcontrib.c: In function `init':
rtcontrib.c:352: error: `SIGINT' undeclared (first use in this function)
make: *** [rtcontrib.o] Error 1
make: Target `install' not remade because of errors.
what is it i'm doing wrong here?
doesnt seem to be an issue with libs/packages/ is it?
Cheers, Jelle
Hi Jelle,
The fault is mine -- apparently, OS X is more generous with it's #include's than Linux. Add the following right after the line:
#include <ctype.h>
at the head of rtcontrib.c:
#include <signal.h>
Hopefully, that should fix it. I'll check in the change tonight, but you don't need to wait for it.
From: Jelle Feringa / EZCT Architecture & Design Research <[email protected]>
Date: May 30, 2005 5:11:55 PM PDT
install linux.
the HEAD release.
Cheers, Jelle
