Date: December 22, 2016 8:42:49 AM PST
Well, the fseeko macro is only used by rcontrib, even though it appears in a header that gets used almost everywhere. So that's unlikely to be the problem.
For what it's worth, I had no problem running that triangle through my compiled oconv. The error seems to indicate some problem reading the real arguments. Does everything work if you remove that triangle from the model? Or is this a problem with reading all polygons?
It's hard to imagine that something like this would change depending on the MVSC version, but I guess if you've eliminated all the other possibilities...
Nathaniel
On Thu, Dec 22, 2016 at 11:08 AM, Victor LRG <[email protected]> wrote:
Nathaniel/Robert,
I've tried compiling 5.0.a.12 and I also get the same C4005 'fseeko' macro definition warning (no more erf/erfc warnings though). Annoyingly, xform/oconv are still giving me the same problems, but I'am not sure if that is related to these warnings.
For now I am still using MVSC2015 and Cmake 3.7.1. I wonder if it is worth trying the older versions you are using. It is a bit of work to remove and reinstall MVSC...
Victor
On 22 December 2016 at 15:11, Nathaniel Jones <[email protected]> wrote:
"Roll your own" has been working fine for me with the GitHub combined branch head, VS2013, CMake 3.3.1, Qt 5.5, and the libtiff rolled from the source files included in the repo. I haven't seed any problems with evalglare, and I believe the erf and erfc warnings were fixed a few months ago. I do get this warning with all the projects now:
1>D:\nljones\Radiance\src\common\platform.h(24): warning C4005: 'fseeko' : macro redefinition
1> command-line arguments : see previous definition of 'fseeko'
Nathaniel
On Thu, Dec 22, 2016 at 10:00 AM, Jan Wienold <[email protected]> wrote:
Hi Rob,
just a short question : is the evalglare-compilation bug for windows solved for the 5.0.a.12 ?
if not, just let me know if you need help for solving. Also give me a hint when a new "big" release is planned.
FYI: I away from 29.12 to 15.12 without access to email
best,
Jan
On 22/12/16 15:39, Guglielmetti, Robert wrote:
What¹s the vintage of the source code? There were a couple of minor
patches to the 5.0 official release (Mid-September), and the last tag that
builds for Windows for me is the 'NREL 5.0.a.12¹ tag:
Release 5.0.a.12 · NREL/Radiance · GitHub
You could try the Windows installers we have, which seem to be working:
https://github.com/NREL/Radiance/releases/download/5.0.a.6/radiance-5.0.a.6
-win64.exe
-win32.exe
I also Œget¹ wanting to roll your own, though. Again you¹d need to make
sure your source aligns with this commit, or earlier:
Changes to compile under Windows · NREL/Radiance@0c84273 · GitHub
d1fc5
And for the record, that NREL Windows build used Cmake 3.3.2, MSVC 12
2013, a libtiff I rolled myself with 4.0.4-beta, and Qt5.3.
The NREL packages aren¹t bulletproof, I¹m finding, but xform and oconv
seem to work fine. It¹d be potentially mutually beneficial for you to try
the NREL package on your input and see what happens. Or, send me your test
input and we can go from there.
On 12/22/16, 5:15 AM, "Victor LRG" <[email protected]> wrote:
Dear all,
I amtrying to compile Radiance 5R0 for Windows using Cmake 3.7.1 x86 and
MVSC 2015 v14 with libtiff 3.8.2 and qt-x86-2.0.4. The compilation
finished with no errors (although some 1700 warnings), but when I am
trying a simple test
I get the following error with ovonv: fatal - (!xform
objects/cage_sphere2.rad): bad arguments for polygon "311s1m134f". This
object has the following description, which seems right to me:
cage_sphere polygon 311s1m134f
9 -0.833925170898 0.506038208008 0.096073600769
-0.819481933594 0.473128112793 0.0903565139771
-0.853187255859 0.492587890625 0.0980178833008
In VS I can see the following warnings regarding oconv and xform:
C4273 'erf': inconsistent dll linkage
C4273 'erfc': inconsistent dll linkage
They both refer to rtmath.h file, which I guess they should refer to
erf.c as well? Actually, this warning also appears for most projects.
I've compiled and used the same package in linux before with no problem.
Any ideas?
Thanks
Victor Lopez-Rioboo Gil
