Compiling rad3R9 on CYGWIN
I've install the latest version of CYGWIN-X with the following packages:
xorg-server
xinit
xorg-docs
X-start-menu-icons
tcsh
nano
tiff
wget
twm
xclock
make
I then downloaded the source code to compile using the CYGWIN option,
but I get the following errors while compiling:
gcc -Dfreebsd -L/usr/lib -L/usr/X11R6/lib -I/usr/include/sys
-I/usr/include/X11 -I/usr/X11R6/include -DNOSTEREO -02 -c -o
unix_process.o unix_process.c
unix_process.c:14:22: sys/wait.h: No such file or directory
unix_process.c: In function 'open_process':
unix_process.c:49: warning passing arg 2 of 'execv' from incompatible
pointer type
unix_process.c:64: error: 'F_SETFD' undeclared (first use in this
function)
unix_process.c:64: error: (Each undeclared identifier is reported only
once for each function it appears in.)
unix_process.c:64: error: 'FD_CLOEXEC' undeclared (first use in this
function)
make: *** [unix_process.o] Error 1
I've checked /usr/include/sys for wait.h and it does exist, so I'm not
sure why I am getting this error. Any thoughts?
Richard
rmarchant@beeryrio.com
