Hi Denny,
I want to know more about why you're using cmake. The cmake build system
was added by NREL as part of their quest to provide windows installers. If
you're using cmake because you want to try it out and work out all the
kinks, then carry on.
If your goal is to install a working HEAD version of Radiance on a linux
os, then you are probably better served using the makeall script. The
makeall script is the most reliable build option for unix type operating
systems (since that is what the Greg uses). Also, makeall.sh is updated by
Greg when he adds new programs - cmake updates take longer because NREL
needs to do them, and pass them back to Greg. Someday cmake might be the
preferred build platform for Radiance, but for now if you're using Linux,
you're better off with makeall.sh. You can follow these instructions
(written for compiling on mac). Ignore the first step - installing xcode.
http://www.radiance-online.org/download-install/installation-information/mac-osx-1#Compiling
Andy
On Thu, Oct 25, 2012 at 8:44 AM, Denny <[email protected]> wrote:
Dear all,
when compiling with static libraries, I get a dependency error when the
program gets packaged for rpm:file:
src/util/trad.wsh:
contains
#!/usr/local/bin/wish4.0
and therefor a dependency is automatically generated for it, which is not
allowed/possible.Solution (if wish is still needed):
Replace the line with
#!/usr/bin/wish
which will create a dependency a tk package meets.
Denny
Am Dienstag, 23. Oktober 2012, 10:36:47 schrieb Guglielmetti, Robert:
> Hi Denny,
> Yeah there really isn't any documentation on the NREL site on how to
> actually use the CMake build system in the Radiance source tree, yet.
Pally> at IESve wrote up a great summary of her experience using CMake and
posted> it here a couple/few months ago.
> Sounds like you have CMake on your system. The quick bullet list of
steps I> do is as follows:
> 1. create build directory in ray/
> 2. cd ray/build
> 3. cmake ..
> 4. ccmake .
> 4a. In the ccmake "gui", type 'c' to configure, fix any errors found
> 4b. Type 'g' to generate themakefiles; ccmake will then exit
> 5. make
> if all goes well, then:
> 6. sudo make install
> Lemme know if that helps.
> - Rob
> ________________________________________
> From: Denny [[email protected]]
> Sent: Tuesday, October 23, 2012 9:10 AM
> To: [email protected]
> Subject: [Radiance-dev] compile radiance HEAD 3332 with cmake on command
> line / linux
> Dear all,
> I tried to compile radiance HEAD 3332 from source (snapshot) on an
openSUSE> 12.2 64bit box with cmake 2.8.9; gcc 4.7.1, but don't get a working
version> of radiance.
> As I couldn't find much documentation on the cmake build for radiance
and I> haven't used cmake much, It would be good to get some guidance.
> Here is what I did:
> 1. Untar src
> /> tar xvf radiance-HEAD-ecd3332.tar.gz
> 2. change into directory and call cmake
> />cd radiance-HEAD-ecd3332
> />cmake src/
> Everything looks good, except for the following warning:
> CMake Warning (dev) in CMakeLists.txt:
> No cmake_minimum_required command is present. A line of code such as
> cmake_minimum_required(VERSION 2.8)
> should be added at the top of the file. The version specified may be
lower>
> if you wish to support older CMake versions for this project. For more
> information run "cmake --help-policy CMP0000".
> This warning is for project developers. Use -Wno-dev to suppress it.
> 3. Build binaries from source
> />make -i
> 4. Install
> />make install -i
> Following things I noticed:
> 1. Build fails when not using -i with make, as there are many issues
> regarding a missing Version.c file, like:
> [ 37%] Built target genworm
> [ 37%] Generating /src/rt/Version.c
> CMake Error: Error processing file:/src/rt/create_version.cmake
> make[2]: *** [/src/rt/Version.c] Error 1
> make[1]: *** [rt/CMakeFiles/radiance.dir/all] Error 2
> make: *** [all] Error 2
> 2. There is no build/ directory created when building that holds the
> resulting binaries etc.
> Questions:
> 1. Is there anything obvious, I should do differently?
> 2. How do I install executables etc. to /usr/ rather than /usr/local/ e.g
> /usr/bin or /usr/share/radiance/ etc. without patching the sources/cmake
> files?
> Thanks for your help.
> Denny
> Radiance-dev mailing list
> http://www.radiance-online.org/mailman/listinfo/radiance-dev
