as (according to Mark's benchmarks) more and more people start to use the fast-math switch when compiling using gcc, I want to share my experience that this option, while improving performance, may lead to the mysterious "zero ray direction in localhit" errors. I have experienced those a lot when using this kind of "optimization", which led me to many many restarts of interrupted renderings, and solved the problem using a new compile with more standard-friendly parameters.
Just a hint... CU Lars.
I am ashamed to admit that I just comment out line 516 in raytrace.c to avoid that error.
//error(CONSISTENCY, "zero ray direction in localhit");
But then, nobody questions the numerical accuracy of my lighting, so I feel somewhat free to experiment.
Mark
On Thu, 17 Apr 2008, Lars O. Grobe wrote:
This reminds me of one of my favorite hardware fixes. My laptop DAC
makes a hideous buzzing sound when plugged into PA amps at electronic
music venues. Of course, this is due to a ground-loop, but isolators
don't totally eliminate the buzz.
The solution? Cut the ground plug off my AC adapter.
(Sorry for running off-topic... and thanks for the hint, Lars)
DR
avoid that error.
Mark
> Hi,
Haha! Don't worry Mark, the Bush Administration is doing similar things to the Constitution.
-Rob
The newer versions of GCC actually do a pretty decent job with just
the -O3 optimisation:
http://www.luxal.eu/resources/radiance/benchmark.shtml
While I have to honestly admit that I don't know the 'perfect' compile
switches for my CPU (I borrowed them from Mark's benchmark page, from
what appeared to be a processor similar to mine), the benchmark shows
that setting too many exotic compiler options might actually decrease
the speed a little.
Axel
