Comparison of values measured by sensors and calculated with Radiance (Greg Ward)
Dear Greg,
Thank you for your advice and I just tried as you said but actually the
results were not improved as following link.
*http://iga.iis.u-tokyo.ac.jp/xe/?document_srl=346*
That might be so because the lamp is actually UV lamp but as you know, there
is almost no difference between flourescent and UV lamps besides with or
without phosphor coating on the surface of lamp. Nevertheless,
I thought the absence of phosphor coating could cause some differences on
the diffuse of UV including the Fresnel effects. I'm finding some references
on the diffuse of UV lamps.
The reflectances were referred to a japanese paper which had done
experiements with UV and the UV output of lamp was referred to the
manufacturer's specification but the UV intensities at 1 m distance is
almost the same.
Additionally, I'm checking the UV sensor but as it also follows cosine law
as illuminance sensors do, there might be no problem with UV sensor.
Sung
Message: 4
Date: Wed, 1 Apr 2009 11:35:14 -0700
Subject: Re: [Radiance-general] Comparison of values measured by
Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
Hi Sung,
Try adding the following parameters to your rtrace command:
       -dj .7 -dt 0
How sure are you of your surface reflectances? Did you actually
measure the lamp output, or are you assuming the manufacturer's lumen
specification is correct? How far off are your values?
Since you notice the most errors near to the lamp and at low angles,
it's possible that the Fresnel effects are important. The emission
of the fluorescent phosphor may be considered diffuse, but the actual
output of the lamp will be a function of angle due to Fresnel
reflection of the glass bulb. You can account for this
(approximately) by applying the "winxmit.cal" function included with
Radiance, like so:
void brightfunc Fresnel_effect
2 winxmit winxmit.cal
Fresnel_effect light lamp_light
3 X X X
lamp_light cylinder fluorescent_tube
(etc...)
I think you get the idea.
Date: April 1, 2009 11:27:29 AM PDT
Dear all,
A bared cylinder lamp (with 60cm length and 3.2cm diameter) is
installed on the wall and illuminance values were measured at some
points and to some directions as shown in the linked image.
Unfortunately, the illuminance values calculated with Radiance are
different from measured values, especially when the sensor is near
the lamp or the incident angles are high (K~O).
Link image
What can be supposed as the cause of the discrepancy?
rtrace command was as follow.
cat pts.pts | rtrace -I -oov -ar 128 -ad 512 -as 256 -ab 2 -ds 0.02
test.oct > test.dat
and all the walls, floor and ceiling was covered with non-glossy
black paper. (reflectance 0.05)
Sung.
