Comparison of values measured by sensors and calculated with Radiance (Greg Ward) (Minki Sung)
Dear Greg,
I have done some additional measurements and the results show as follow.
http://iga.iis.u-tokyo.ac.jp/tmp/test01.gif Setup
http://iga.iis.u-tokyo.ac.jp/tmp/test02.gif Fluorescent lamp (Measurement)
http://iga.iis.u-tokyo.ac.jp/tmp/test03.gif Simulation
http://iga.iis.u-tokyo.ac.jp/tmp/test04.gif UV lamp (Measurement)
The results indicate the UV lamp has different diffuse characteristics
compared with common fluorescent lamps if the UVC sensor is cosine corrected
well as written in the sensor. If there is no problem with UVC sensor, it
might be not easy to model UV lamp with RADIANCE.
Best Regards,
Sung
