Hi German,
Sorry to have taken so long to respond. When I first read your email I
didn't have time to dig in and planned to come back to it. Then I promptly
forgot about it.
The one thing that stands out, and could be a major source of error for a
clear sky is the ground reflectance. You're using 70% in the rtraced model,
but you aren't using it in the 5-phase method. Though if you have large-ish
local ground plane defined in scene.rad (which you always should, but even
the best of us sometimes leave out) this will be less of a problem.
You can specify ground reflectance in gendaymtx with the -g argument. The
default is -g 0.2 0.2 0.2 (which is a lot different from 70%). You
gendaymtx command would look something like this:
gendaymtx -h -g 0.7 0.7 0.7 -m 1 Santiago.wea > full_sky.skv
Let me know if this doesn't improve things and I'll dig in further.
Andy
On Tue, Sep 9, 2014 at 8:41 AM, CHI-German Molina <gmolina@hdlao.com> wrote:
Dear All,
I have been trying to replicate the "DAYSIM Daylight Coefficients",
comparing those results with the RTRACE output. I am doing this following
the 5 phase method tutorial, but I have not been succesful yet. Any
comments would be great! I am not sure I am doing this well...So, what I did is to separate the whole scene (including overhangs) from
the window.*FILE CONTENT*
##White.sky
void glow skymat
4 1 1 1 0skymat source skysource
4 0 0 1 360## suns.rad
void light solar 0 0 3 1e6 1e6 1e6
solar source sun 0 0 4 0 0.999 0.018 0.018 0.533
lots of them.## black.rad
void plastic black
5 0 0 0 0 0##clear.sky
!gendaylit 3 1 9.5 -W 756 189 -g 0.7 -a -33.38 -o 70.78 ##There is a
big ground with 70% reflectanceskyfunc glow skyglow
4 1 1 1 0skyglow source skysource
4 0 0 1 360##Santiago.wea
place SANTIAGO_CHL
latitude -33.38
longitude 70.78
time_zone 60
site_elevation 476.0
weather_data_file_units 1
1 1 9.5 756 189*RTRACE CALCULATIONS*
oconv Materials/* scene.rad clear.sky windows.rad > clear_octree.oct
cat Workplanes/WP.pts | rtrace -n 4 -I -ab 8 -ad 50000 -lw 2e-5 -dc 1 -dt
0 -dj 0 -st 1 -ss 0 -faa -af amb.af clear_octree.oct > rtrace.lux*DC CALCULATIONS*
#Full sky DC
oconv Materials/* scene.rad windows.rad white.sky > white_octree.oct
gendaymtx -h -m 1 Santiago.wea > full_sky.skv
cat Workplanes/WP.pts | rcontrib -e MF:1 -f reinhart.cal -b rbin -bn
Nrbins -m skymat -n 4 -I -ab 8 -ad 50000 -lw 2e-5 -dc 1 -dt 0 -dj 0 -st 1
-ss 0 white_octree.oct > DC1.mtx
dctimestep -n 1 DC1.mtx full_sky.skv > DC1.lux#Direct sun from patches, to be sustracted
xform -m scene.rad > black_scene.rad
oconv Materials/* black.rad black_scene.rad windows.rad white.sky >
black_octree.oct
gendaymtx -h -m 1 -d Santiago.wea > sun_only_sky.skv
Nrbins -m skymat -n 4 -I -ab 1 -ad 50000 -lw 2e-5 -dc 1 -dt 0 -dj 0 -st 1
-ss 0 black_octree.oct > DC2.mtx
dctimestep -n 1 DC2.mtx sun_only_sky.skv > DC2.lux#Sharp sun addition
oconv Materials/* black.rad black_scene.rad windows.rad suns.rad >
suns_octree.oct
gendaymtx -h -m 6 -5 Santiago.wea > direct_sun_M6_sky.skv
cat Workplanes/WP.pts | rcontrib -n 4 -I -ab 1 -ad 50000 -lw 2e-5 -dc 1
-dt 0 -dj 0 -st 1 -ss 0 -e MF:6 -f reinhart.cal -b rbin -bn Nrbins -m solar
suns_octree.oct > directsun.mtx
dctimestep -n 1 directsun.mtx direct_sun_M6_sky.skv > directSun.luxThe results are horrible!!! So, any help would be awesome!!! THANKS
*Germán Molina L.*
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445*Nota de Confidencialidad:* Este mensaje incluído los archivos adjuntos
son confidenciales y pueden contener informacion privilegiada protegida por
gracias.*Confidentiality Notice:* The information contained in this email
message, including any attachment, is confidential and is intended only for
the person or entity to which it is addressed. If you are neither the
intended recipient nor the employee or agent responsible for delivering
this message to the intended recipient, you are hereby notified that you
may not review, retransmit, convert to hard copy, copy, use or distribute
this email message or any attachments to it. If you have received this
email in error, please contact the sender immediately and delete this
message from any computer or other data bank, Thank you.A informação transmitida é confidencial e para conhecimento exclusivo do
antivírus antes de qualquer uso._______________________________________________
