combing raw pictures with raw2hdr
Hello everyone,
I’m trying to combine multiple raw pictures using raw2hdr under Linux (I downloaded the files on http://www.anyhere.com/gward/pickup/raw2hdr.tgz) .
I used the following command line <sudo perl raw2hdr -o test.hdr test002?.cr2> (my raw files are on https://www.dropbox.com/sh/hx9vf2fedxkk4qk/AACBXqVZZtmxujIj7eO1fwoda )
I get the following error message:
/usr/bin/dcraw: 1: /usr/bin/dcraw: ����
�T
r�
                                                     : not found
/usr/bin/dcraw: 1: /usr/bin/dcraw: Syntax error: Unterminated quoted string
dcraw failed at raw2hdr line 98.
Does anybody have an idea of the problem? Or a suggestion for combining these images in another way ?
Thanks in advance for your help.
Coralie
Coralie Cauwerts
Research assistant | Eng. in Architecture | PhD
UCL - Université catholique de Louvain
Place du Levant, n°1 – 1348 Louvain-la-Neuve (Belgium)
Tel: +32 (0)10 47 21 42 - Fax: +32 (0)10 47 21 50
It sounds as though your dcraw binary isn't compatible with your version of Linux. You can download and compile a new binary from:
  http://www.cybercom.net/~dcoffin/dcraw/
Subject: [HDRI] combing raw pictures with raw2hdr
Date: May 21, 2014 5:58:14 AM PDT
Hello everyone,
I’m trying to combine multiple raw pictures using raw2hdr under Linux (I downloaded the files on http://www.anyhere.com/gward/pickup/raw2hdr.tgz\) .
I used the following command line <sudo perl raw2hdr -o test.hdr test002?.cr2> (my raw files are on Dropbox - Error - Simplify your life )
�T
r�
                                                     : not found
Coralie
Coralie Cauwerts
HDRI mailing list
Thanks Greg.
Now it works (after having slightly modified the raw2hdr Perl script because my hdrgen program does not recognize the -c option...).
Coralie
-----Message d'origine-----
De : [email protected] [mailto:[email protected]]
Envoyé : mercredi 21 mai 2014 21:00
À : [email protected]
Objet : HDRI Digest, Vol 71, Issue 1
Send HDRI mailing list submissions to
When replying, please edit your Subject line so it is more specific than "Re: Contents of HDRI digest..."
Today's Topics:
   1. combing raw pictures with raw2hdr (Coralie Cauwerts)
   2. Re: combing raw pictures with raw2hdr (Gregory J. Ward)
Message: 1
Date: Wed, 21 May 2014 12:58:14 +0000
To: "[email protected]" <[email protected]>
Message-ID:
  <[email protected]>
Hello everyone,
I?m trying to combine multiple raw pictures using raw2hdr under Linux (I downloaded the files on http://www.anyhere.com/gward/pickup/raw2hdr.tgz\) .
I used the following command line <sudo perl raw2hdr -o test.hdr test002?.cr2> (my raw files are on Dropbox - Error - Simplify your life ) I get the following error message:
/usr/bin/dcraw: 1: /usr/bin/dcraw: ???
?T
r?
                                                     : not found
/usr/bin/dcraw: 1: /usr/bin/dcraw: Syntax error: Unterminated quoted string dcraw failed at raw2hdr line 98.
Coralie
Coralie Cauwerts
UCL - Universit? catholique de Louvain
Place du Levant, n?1 ? 1348 Louvain-la-Neuve (Belgium)
URL: <http://www.radiance-online.org/pipermail/hdri/attachments/20140521/33183108/attachment-0001.html&gt;
Message: 2
Date: Wed, 21 May 2014 10:00:46 -0700
To: High Dynamic Range Imaging <[email protected]>
Subject: Re: [HDRI] combing raw pictures with raw2hdr
Hello everyone,
?T
r?
                                                     : not found
Coralie
Coralie Cauwerts
UCL - Universit? catholique de Louvain Place du Levant, n?1 ? 1348
HDRI mailing list
URL: <http://www.radiance-online.org/pipermail/hdri/attachments/20140521/b6f4c741/attachment-0001.html&gt;
HDRI mailing list
End of HDRI Digest, Vol 71, Issue 1
