I have some HDR images captured by a fisheye lens, and I want to clean it
up to only show the circular image in a black background.
Can anyone help me with the pcomb command to mask off the circular image.
Leyla
Leyla
Something like:
pcomb -e 'Cx:xmax/2;Cy:ymax/2;R:if(Cx-Cy,Cy,Cx);sq(x):x*x' -e 'inC=sq(R)-sq(x-Cx)-sq(y-Cy)' \
-e 'ro=if(inC,ri(1),0);go=if(inC,gi(1),0);bo=if(inC,bi(1),0)' -o input.hdr > cropped.hdr
You may have to adjust the definitions of R and/or Cx and Cy if your circle doesn't completely fill one dimension of the image.
Date: February 19, 2013 9:51:12 AM PSTHi,
I have some HDR images captured by a fisheye lens, and I want to clean it up to only show the circular image in a black background.
Can anyone help me with the pcomb command to mask off the circular image.Thanks,
Leyla
Leyla,
There may be a better way, but I generally will open a single image into
my Photoshop to create my mask. Create an image with the fisheye portion
you want to keep black and the part you want masked out white. Save this
as a .tiff file in your working directory.
In Radiance, you will first need to convert the tiff into an hdr. This
is done by the following command: ra_tiff -r filename.tiff mask.hdr
To mask out your captured hdr using pcomb, this should work: pcomb
captured.hdr -s -1000 mask.hdr > output.hdr (or pipe to another
process).
The "-s -1000" portion of the pcomb command should be sufficient, but if
you have some remaining pixels in the masked area, try a different
scaling factor (-10000, etc).
Good luck.
Chris
Chris Coulter
Senior Lighting Designer
Buro Happold Consulting Engineers
100 Broadway, 23rd Floor
New York, NY 10005
Tel: 212.334.2025
Direct: 212.616.0254
Email: [email protected]
Website: www.burohappold.com
Sent: Tuesday, February 19, 2013 12:51 PM
To: [email protected]
Subject: [HDRI] Cleaning the HDR image with pcomb
image.
Leyla
