Hello All,
I want to use evalglare to evaluate glare in radiance images. I generated
images by three phase method, unfortunately header of those images does not
include view information, which I think that evalglare looks for
explicitly.
I have tried to change the image header just in text editor but it did not
work and demage the image. I would like to ask how to change the header, I
know that it may be trivial but I did spend some time on it already and did
not find how to do it yet.
Thank you for all advices.
David
Use:
getinfo < orig.hdr > modified.hdr
# modify "modified.hdr" using favorite text editor, keeping final empty line (and no others)
getinfo - < orig.hdr >> modified.hdr
If you're just adding a view line to the header, you could use:
echo "VIEW= -vta -vh 180 -vv 180" > modified.hdr
cat orig.hdr >> modified.hdr
The latter method messes up the header slightly, but should still work.
Date: December 9, 2011 3:28:10 PM PST
Hello All,
I want to use evalglare to evaluate glare in radiance images. I generated images by three phase method, unfortunately header of those images does not include view information, which I think that evalglare looks for explicitly.
I have tried to change the image header just in text editor but it did not work and demage the image. I would like to ask how to change the header, I know that it may be trivial but I did spend some time on it already and did not find how to do it yet.
David
Thank you Greg, it is working.
Is there way how to include the view information in the header directly,
instead of manipulating header for each picture?
Best
David
On 9 December 2011 15:39, Greg Ward <[email protected]> wrote:
Use:
> From: David Appelfeld <[email protected]>
> Hello All,
> David
Hi David,
Similar to rtrace, on which it is based, rtcontrib has no notion of what a picture is. The output from it is consequently lacking information you would get out of rpict or rvu for example. There is no easy fix to this, other than scripting something to post-process the output as I suppose you are doing.
Date: December 9, 2011 4:03:43 PM PST
Is there way how to include the view information in the header directly, instead of manipulating header for each picture?
Best
David
Use:
> Hello All,
> David
thank you for explanation, it is clear now.
David
On 9 December 2011 16:12, Greg Ward <[email protected]> wrote:
Hi David,
are doing.
*Date: *December 9, 2011 4:03:43 PM PST
Best
David
Use:
> Hello All,
> David
