Hi Shrikar,
I suppose you have discovered the -pal and -palettes options, but this still doesn't give you what you want?
You can create custom scales using the -r, -g and -b options. Here is an example for a 3-step blue-yellow-white scale:
falsecolor �ip picture.hdr �s 5000 �r �if(v-0.3,1,0)� \
�g �if(v-0.3,1,0)� �b �if(v-0.3,if(v-0.7,1,0)1)� > picture_fc.hdr
It requires a bit of cal magic. You may also look at the falsecolor code for inspiration.
Best
Axel
On 28/08/14 21:20, Shrikar Bhave wrote:
Hello All,
Got this unusual request. I am not sure how I can change that. Any
pointers?
Can I set custom colors based on say min/max and number of desired steps
in between?
I am looking at both Luminance and Illuminance falsecolor images.
Has anyone attempted that before, if yes, any examples?
Shri
P.S> Apologies for my past emails with attachments, I promise I will be
diligent next time!
HI Axel,
So far, I had not come across -pal and -palettes options! I will look into
it. Thanks for the command for the custom scales, that looks promising. My
initial reaction was I will need to tweak/play with the code for
falsecolor, but this looks like something I can actually do ![:slight_smile: :slight_smile:](https://discourse.radiance-online.org/images/emoji/twitter/slight_smile.png?v=12)
Thanks a lot!
Shri
On Thu, Aug 28, 2014 at 4:32 PM, Axel Jacobs <[email protected]> wrote:
Hi Shrikar,
falsecolor –ip picture.hdr –s 5000 –r ‘if(v-0.3,1,0)’ \
–g ‘if(v-0.3,1,0)’ –b ‘if(v-0.3,if(v-0.7,1,0)1)’ > picture_fc.hdr
for inspiration.
Best
Axel
Hello All,
pointers?
in between?
Shri
diligent next time!
