The luminance calculation given in the paper (as Matlab algorithm) should be exactly the same as Photosphere uses to calculate luminance. Greg is the only person to verify this I guess
The calculations are based on CIE chromaticities for the reference primaries (sRGB) and CIE Standard Illuminant D65:
R (x, y ,z) = (0.64, 0.33, 0.03)
G (x, y, z) = (0.30, 0.60, 0.10)
B (x, y, z) = (0.15, 0.06, 0.79)
D65 (x, y, z) = (0.3127, 0.3290, 0.3583)
In Radiance on the other hand, calculations are based on equal energy white point. Equal energy (x, y, z) = (0.33 0.33 0.33).
That is the reason for minor difference between original Luminance calculations in Radiance (R*0.265 + G*0.067 + B*0.065) and the calculation in the paper (R*0.2127 + G*0.7151 + B*0.0722). My two cents is that the difference in between those two equations is quite minor.
It is true that the saturated colors in Macbeth chart yielded increased errors. RAW format might result in better results, but I don't have enough data to claim that... My limited trials with RAW formats looked quite promising though.
Some of the folks in this group may comment on their experience with RAW format, may be?
Mehlika
On Tue, 26 Sep 2006, Blochi wrote:
That study is a very interesting read. Thank you for the link. And thank you for taking the time to do this elaborate analysis in the first place.
It makes me wonder how closely your Mathlab algorithm for calculating the luminance is related to the Photosphere's algorithm. Does the determined 10% average accuracy apply to Photosphere's luminance readout as well, provided we work off a good calibration curve?
Also, I find it interesting that the error is higher for primary colors, with Red going up to 40% sometimes. Those really seem to drive up the average a lot. Could the limited gamut of the Radiance format itself have an influence here? Or is it really all due to the cameras internal demosaicing and JPEG compression? Could this error be minimized by shooting RAW pictures instead?
Christian
Am 26.09.2006 um 13:33 schrieb Mehlika Inanici:
You may want to look at the validation study at:
Inanici MN. “Evaluation of High Dynamic Range Photography as a Luminance Measurement Technique”, Journal of Lighting Research and Technology, Vol. 38, no. 2, June 2006, pp. 123-136.
Another version of this study is available at:
http://repositories.cdlib.org/lbnl/LBNL-57545/
This study evaluates Photosphere rather than HDRShop, but you can find information regarding your first 3 questions.
Hope this helps... Regards,
Mehlika
On Tue, 26 Sep 2006, Pierre-Felix Breton wrote:
Hi!
I am experimenting with HDR images and a luminance meter to see how tone
mappers can actually help reproducing human perception.
Here is what I am currently doing:
a)capture a serie of LDR images using a Canon Rebel XT, only changing the
shutter speed, with constant Fstop, saved as JPG with sRGB profile
b)creating a calibration curve in HDR Shop
c)measuring a few points in cd/m2 with a luminance meter (LS-110)
d)making an HDR image out of the LDR images using the calibration curve
e)experimenting different tone mappers available on the DVD of the HDRI book
from our favorite well known HDRI gurus.
Here are a few questions that puzzles me still:
1) I am trying to scale my HDR image to the measured physical values. I
found somewhere that luminance = 179 * (R*0.265 + G*0.067 + B*0.065). Can I
assume that this equation is the one to use to scale my HDR file properly?
2) In some references, it is mentionned that I should always capture LDRs
with a Daylight white balance. Is this the general agreement? Even if my
scene is lit with tungsten lights?
3)I found limited explanation on how the camera calibration curve would
affect the results in HDR Shop. I would have to think that this is to
linearize the color values (remove the effect of Gamma + CMOS response) so
luminance measurements can be actually applied to the colors later on.
4)HDR Shops refers to Fstops in the UI. However, I read that you want to
maintain Fstops constant and only change the shutter speed. The problem I
have is that the interpreted Fstops of HDR Shop turn into some "arbitrary"
numbers and I can't really type-in the values used by my camera.
I am not too sure if I am using the right methods. Some "cook book" would
be handy.
Best regards,
Pierre-Félix Breton
www.pfbreton.com <http://www.pfbreton.com/>
HDRI mailing list
HDRI mailing list
