For me, the difference of the real picture and the simulation is quite visible. Maybe this discussion topic is one reason for this.
We came across this issue by doing a combined thermal and dynamic daylight analysis.
One calculation with original DAYSIM and one DAYSIM calculation with sun position calculated from TRNSYS.
There were quite visible differences, especially in Autumn.
https://drive.google.com/file/d/0B_k3K9s5QAlISGdYWFdlMHZFc00/view?usp=sharing
and
https://drive.google.com/file/d/0B_k3K9s5QAlIb0lRN3VrdXVQaFU/view?usp=sharing
TRNSYS uses the Spencer-Algorithm from 1971 for the calculation of solar declination.
Implementing this Algorithm is easy because it has just a few more sin() and cos() statements .
This graph:
https://drive.google.com/file/d/0B_k3K9s5QAlIbWVXZHhINXhYTDA/view?usp=sharing
shows the differences between this algorithm, the Cooper Algorithm and the Algorithm used in Radiance.
So my first question is answered by this. By using 368 days per year the deviation is smaller than with the original
Cooper Algorithm.
A good starting point for choosing the right algorithm could be in my opinion :
�Computing the solar vector� in Solar Energy Vol. 70, No. 5, pp. 431�441, 2001 by MANUEL BLANCO-MURIEL et al.
Here, the differences of common algorithm are described. They use only the Spencer Algorithm as an example of a simple algorithm.
Following table shows, that there are considerable differences:
https://drive.google.com/file/d/0B_k3K9s5QAlIcS1JQmZFSGttbWs/view?usp=sharing
They recommend the Michalsky-Algorithm or their own PSA-Algorithm, which is a little bit better.
The Michalsky Algorithm is also used in the program SolPos Nathaniel Jones recommended:
https://www.nrel.gov/midc/solpos/
The Source Code for the PSA-Algorithm is available under:
http://www.psa.es/sdg/sunpos.htm
It seems to be comparable to the from Christian Humann recommended NREL algorithms which is used in the program spa:
Solar Position Algorithm (SPA)
From my point of view as a user it would be desirable, that the main used Simulation Programs uses the same or at least quite similar algorithm for calculating the sun position.
TRNSYS uses the Spencer-Algorithm, which is due to the upper publications also not the best choice.
It would be interesting what algorithm EnergyPlus uses.
Regards
Martin
*Von:*Christoph Reinhart [mailto:tito_@mit.edu]
*Gesendet:* Donnerstag, 17. Dezember 2015 18:29
*An:* Radiance general discussion
*Betreff:* Re: [Radiance-general] Calculation of solar declination in sun.c
Using a more accurate formula that is based on a respectable source like a good idea if the magnitude of the correction is as large as Martin describes. Incidentally, we are having our students do �validations� of the formula by comparing the photograph of an objects as a certain time in the year to a Radiance rendering and that analysis tends to come out pretty well: http://web.mit.edu/sustainabledesignlab/projects/DaylightingHandbook/Exercise_DirectSunlight.htm\.
Christoph
*Sent:* Thursday, December 17, 2015 12:22 PM
*To:* Radiance general discussion <[email protected] <mailto:[email protected]>>
*Subject:* Re: [Radiance-general] Calculation of solar declination in sun.c
Given the tool construction, it would be simple enough to introduce a global variable that switches between the de facto solar angle calculation and a more precise version. I'd like to hear from others that this is worthwhile before I spend too much time on it, though. Also, whether it should be exposed as an option in all of the calling programs (i.e., IES calculation or more accurate on).
Is there a general consensus on which solar calculation is best? I would just end up googling it, unless you or someone else has a strong recommendation.
*From: *Martin Gut <[email protected] <mailto:[email protected]>>
*Subject: *Re: [Radiance-general] Calculation of solar declination
in sun.c
*Date: *December 17, 2015 8:55:38 AM PST
Thank You for the quick answer. I don�t know about the history of
this debate because I�m quite new in this mailing list.
I think for the CIE standard stuff, sticking on the standard
routines is ok.
But this formula is also used for all the dynamic daylighting
stuff like
Gendaymtx
Gendaylit
Daysim
etc.
also for shading studies: I�m wondering that so much computing
effort is investigated to render the shading and on the other side
the position of this shading is incorrect (especially in Autumn)
because of
a very rough calculation of the sun position. The error is not so
big, but it could be avoided very easy by using a better formula
for solar declination.
Maybe there could be two functions, one for the standard
calculations and one for �real� calculations.
Martin
*Von:*Greg Ward [mailto:[email protected]]
*Gesendet:* Donnerstag, 17. Dezember 2015 17:14
in sun.c
Hi Martin,
This debate comes up every so often with the solar calculations
used in Radiance and related tools. The main question is, do we
stick with the established standard, which provides for easy
"apples to apples" comparisons, or do we update our formulas to
get a more precise answer? In the case of the original CIE sky
models, which this solar calculation is used in primarily, the
accuracy is not that great, so getting the sun in exactly the
right place is a minor quibble. If, on the other hand, you need
precise sun position for solar shading studies or the like, then
it's easy to argue for a better formula. I don't think computing
power was ever the issue with Radiance. We don't compute the sun
position for every ray-traced or anything silly like that.
As Rick points out, the use of 368 is part of the IES standard
calculation, but I'm not entirely sure what anomaly it is
correcting for.
in sun.c
*Date: *December 17, 2015 7:18:53 AM PST
I�m not certain why it is 368, but this equation has been in
this format in the IES Lighting Handbook for many years.
Rick
*Sent:* Thursday, December 17, 2015 6:05 AM
Dear Radiance Experts,
I have two questions regarding the calculation of solar
declination:
1.Why has the year in function sdec in file sun.c 368 days
instead of 365 as in the original formula from Cooper ?
return( 0.4093 * sin( (2*PI/368) * (jd - 81) ) )
Radiance/src/gen/sun.c at master · NREL/Radiance · GitHub
2.Why does Radiance not use a better formula, which takes into
account, that the Earth orbit is not a circle?
With today computing power, there is no more reason to use
this simple formula
Thanks in advance
Martin
