calculation of one reflection (rtrace)
I try to understand how RADIANCE calculate the radiance values, but the specular value for one reflection isn't clear.
I understand, that the diffuse value is independent of view. On point P_r=(0 1 1) I got from rtrace for the red channel 0.22361, I calculated:
R_r_light=100
sphere_radius=0.5
distance=2.2360
rho_surf1=0.1
cos(63,43) = light incoming angle
R_r(0,1,1) = R_r_light * (sphere_radius)² / (distance)² * cos (63,43) * rho_surf1 = 0.223606797.
Ok, this value is fine, but what will happen if I look from (0 -1 1) to (0 1 -1) at point (0, 0, 0), I thought this, but it didn't work:
distance=3
rho_mirr=0.3
diff=0.9
spec=0.1
cos(45) = reflected light - observer angle
P_r=0.22361
R_r(0,0,0) = R_r_light * (sphere_radius)² / (distance)² * rho_mirr * diff + spec * P_r * cos(45) = 0.765811388
rtrace = 0.76517
Can somebody explain how the specular component is calculated on my test scene? I do not get it...
Here is my test scene:
######materials.rad######
void plastic mirr
5 .3 .2 .1 0.1 0
void plastic surf1
5 .1 .1 .1 0 0
void light lighty20
3 100 150 200
######test.rad######
mirr polygon plate1
12
-1 -1 0
  1 -1 0
  1 1 0
-1 1 0
surf1 polygon plate2
12
-1 1 0
-1 1 3
  1 1 3
  1 1 0
lighty20 sphere light_s
4 0 0 3 0.5
Hi Robert,
There is a Fresnel correction that puts more energy into the specular component at low angles, and even though 45 degrees isn't a very low angle, your differences are in the 4th significant digit. I think this is the source of the discrepancy.
Date: June 27, 2012 2:41:26 PM PDT
R_r_light=100
sphere_radius=0.5
distance=2.2360
rho_surf1=0.1
distance=3
rho_mirr=0.3
diff=0.9
spec=0.1
P_r=0.22361
rtrace = 0.76517
void plastic mirr
5 .3 .2 .1 0.1 0
void plastic surf1
5 .1 .1 .1 0 0
void light lighty20
3 100 150 200
mirr polygon plate1
12
-1 -1 0
1 -1 0
1 1 0
-1 1 0
12
-1 1 0
-1 1 3
1 1 3
1 1 0
4 0 0 3 0.5
I found the Fresnel correction on this paper, thanks for the hint:
http://radsite.lbl.gov/radiance/refer/materials.pdf
How does RADIANCE calculate the index of refrecation of plastic?
Rob
Am 28.06.2012 01:30, schrieb Greg Ward:
Hi Robert,
R_r_light=100
sphere_radius=0.5
distance=2.2360
rho_surf1=0.1
distance=3
rho_mirr=0.3
diff=0.9
spec=0.1
P_r=0.22361
rtrace = 0.76517
void plastic mirr
5 .3 .2 .1 0.1 0
void plastic surf1
5 .1 .1 .1 0 0
void light lighty20
3 100 150 200
mirr polygon plate1
12
-1 -1 0
1 -1 0
1 1 0
-1 1 0
12
-1 1 0
-1 1 3
1 1 3
1 1 0
4 0 0 3 0.5
Hi Rob,
You really need to refer to the code if you want this level of detail. The paper you mention talks about Fresnel reflection, but these formulae are only applied for glass and dielectric. Plastic uses an approximation developed independently by myself and another researcher, Christoph Schlick:
  http://en.wikipedia.org/wiki/Schlick’s_approximation
If you look in ray/src/rt/normal.c, you will find it there.
Date: June 29, 2012 4:32:13 AM PDT
Rob
Hi Robert,
R_r_light=100
sphere_radius=0.5
distance=2.2360
rho_surf1=0.1
distance=3
rho_mirr=0.3
diff=0.9
spec=0.1
P_r=0.22361
rtrace = 0.76517
void plastic mirr
5 .3 .2 .1 0.1 0
void plastic surf1
5 .1 .1 .1 0 0
void light lighty20
3 100 150 200
mirr polygon plate1
12
-1 -1 0
1 -1 0
1 1 0
-1 1 0
12
-1 1 0
-1 1 3
1 1 3
1 1 0
4 0 0 3 0.5
