I know this has been discussed before -
I've been searching the archives and found one could use texdata to make an
image-based bump map.
http://radsite.lbl.gov/radiance/pub/digest/no_Z/v2n4
Simon Crone - are you out there? Can you shed some light for me?
In the end, I'm looking for a way to produce the textures of interior walls
. In the past, I've generated noise in Photoshop, blurred it and used Find
Edges filter.
If there's a way to do this some other way, I'd be open. The Puckered
material in the Cabin scene is'nt quite what I'm looking for.
thanks
Rob Fitzsimmons
Hi Rob,
if you're one of the adventurous kind you may have a look into my 2002 workshop contribution. I've prepared some complex .cal -files for mathematical color and/or surface-normal -pattern generation. I admit that this all is a bit awkward, as there are a lot of cryptic parameters. On the other hand, this complexity allows the realistic modelling of a lot of common building materials (including, a.o., rough wall textures)
-Carsten
Rob
Many moons ago I did write some code to enable the use of images as bump
maps.
After a bit of diging though my archives I found the following.
Attached is the modified source from R2.1 and some documentation.
I think the WARNING in the texpict.html says it all
HTH
Simon
texpict.zip (7.65 KB)
----- Original Message -----
To: <[email protected]>
Cc: <[email protected]>
Sent: Saturday, September 06, 2003 7:18 AM
Subject: [Radiance-general] bump mapping
an
walls
Edges filter.
thanks
Rob Fitzsimmons
Thanks to Simon and Carsten
I'll give them a shot
Rob
To: [email protected]
Sent: 9/8/2003 3:57 AM
Subject: Re: [Radiance-general] bump mapping
Rob
bump
maps.
HTH
Simon
