Building Radiance 3.5 on Tru64
Has anyone any experience building Radiance 3.5 on Compaq tru64
systems ? I am trying this, and having some difficulty.
Initially, I was getting errors in the librt build due to conflicting
definitions of random functions. I have cut down the file random.h
to a minimum (included below) and now can get all the programs built
without errors (although warnings are quite numerous).
On running the oconv program on a file cut from the tutorial I get:
cropwell2$ /opt/pkg/radiance/bin/oconv room.rad
#?RADIANCE
FORMAT=Radiance_octree
/opt/pkg/radiance/bin/oconv: fatal - bad # arguments for light "bright"
the room.rad is also included below. Any advice would be welcome.
regards,
Colin Bannister
room.rad:
# My first scene.
# The basic primitive format is:
# modifier TYPE identifier
# number_string_arguments [string arguments...]
# number_integer_arguments [integer arguments...]
# number_real_arguments [real arguments...]
# The special modifier "void" means no modifier.
# TYPE is one of a finite number of predefined types, and
# the meaning of the arguments following is determined by
# this type. (See RADIANCE Reference Manual for details.)
# The identifier may be used as a modifier later
# in this file or in files following this one.
# All values are separated by white space
# (spaces, tabs, newlines).
# this is the material for my light source:
void light bright
3 100 100 100
# red_emission green_emission blue_emission #
# this is the material for my test ball:
void plastic red_plastic
5 .7 .05 .05 .05 .05
# red green blue specularity roughness #
# here is the light source:
bright sphere fixture
4 2 1 1.5 .125
# xcent ycent zcent radius #
# here is the ball:
red_plastic sphere ball
4 .7 1.125 .625 .125
random.h:
/* RCSid $Id: random.h,v 2.9 2003/02/25 02:47:21 greg Exp $ */
* random.h - header file for random(3) and urand() function.
#include "copyright.h"
#define frandom() random()
#define urand(i) frandom()
extern unsigned short *urperm;
Dr. Colin Bannister
Information Services Tel: 0115 9513326
Cripps Computing Centre
The University of Nottingham Fax: 0115 9513358
Nottingham NG7 2RD
www: http://www.nottingham.ac.uk/~cczcb/
email: [email protected]
Unless people feel strongly otherwise, I'm going to suggest we move this discussion to the radiance-dev list.
The error you get from oconv suggests that its getting confused about basic types, as the "bad # arguments" should not show up at all unless it thinks the light is a sphere or a face or something.
My first suggestion is that you try building from CVS head, which may be found on the radiance-online.org site under the "download Radiance" link. Download the current experimental bug-fix version, called radiance-HEAD.tgz, and compile from that. If you still get compile errors with the latest random.h, please forward them directly to me and I'll see what I can do. It's probably best to send me the entire output of makeall.
Begin forwarded message:
Date: Wed Jul 2, 2003 2:15:43 AM US/Pacific
Subject: [Radiance-general] Building Radiance 3.5 on Tru64
#?RADIANCE
regards,
Colin Bannister
room.rad:
# My first scene.
void light bright
3 100 100 100
4 2 1 1.5 .125
# here is the ball:
random.h:
/* RCSid Id: random\.h,v 2\.9 2003/02/25 02:47:21 greg Exp */
Dr. Colin Bannister
Nottingham NG7 2RD
