Subject: Re: [Radiance-general] BSDF question
Date: July 7, 2014 7:39:33 AM PDT
Andy,
How about using BSDFs for ray-tracing calculations? Does it use reciprocity as well? or should we calculate +b ?
Also, was I correct when I said that the BSDFd "Proxy Geometry" is only used for ambient calculations, and the geometry for Direct?
THANKS!
German
2014-07-07 10:32 GMT-04:00 Andrew McNeil <[email protected]>:
Hi Giuseppe,
You only really need either +f or +b, not both. genBSDF does +b by default so if you only wanted to do the forward direction you should use +f -b. Doing one direction takes about half as much time as doing both directions. However, if you want to import into Window you'll need to do both directions.
Andy
On Thu, Jul 3, 2014 at 12:45 AM, Giuseppe De Michele <[email protected]> wrote:
Germán and Andy,
meanwhile thank you for the answers and sorry if my questions are a little bit confused. I am a newbie of the "lighting art" and I am studying this concepts almost alone.
So if I understood, when I create a BSDF matrix with genBSDF I add the +f +b options in order to obtain both transmission matrix and then dctimestep does the rest, doesn't it?
Thanks for yours great help,
Giuseppe
2014-07-02 19:12 GMT+02:00 Andrew McNeil <[email protected]>:
Giuseppe,
The front/back inconsistency is mostly related to the BSDF material primitive. For the 3-phase method you don't have to worry about front/back of the fenestration. (unless you want to use a BSDF backwards, which might be impossible without manually editing the BSDF file).
The BSDF handling has matured quite a bit since the early days of the three-phase method. These days dctimestep can use either front transmission or back transmission applying reciprocity principles for the three phase method.
Andy
On Wed, Jul 2, 2014 at 9:24 AM, CHI-German Molina <[email protected]> wrote:
Guiseppe,
The three-phase method simulation method does not use the geometry of the shading device to work. In fact, one advantage of it is that only the BSDF.xml file is needed. If you check Andy's Three-phase method tutorial, you will see that the calculation of the V and D matrices do not require neither the geometry of the shading device nor the BSDF of it (thus making it very easy to try multiple fenestration systems).
Adding Geometry information to the BSDF file is useful for using pkgBSDF; not really for the 3phase method. When rays have to go through the fenestration system (i.e. rendering a room with venetian blinds, or when calculating the third matrix of the 5 phase method) a combination of two illums that "wrap" the geometry and the geometry itself seems to be more efficient. My understanding (I might be completely wrong) is that the illums are used to transfer the diffuse (indirect??) radiation; and the geometry is used for transfering direct radiation, casting shadows.
My answer to the first question:
1. in the equation i=VTDs the T matrix has to contain the window geometry or take knowledge of these from the other two matrix(V,D)?
Nope. After the V and D matrices are calculated, the simulation is performed by simply multiplying matrices... no geometry.
The second question is something that confuses me... it would be good to have clarification here.
Hope this helps!
Germán
2014-07-02 11:54 GMT-04:00 Giuseppe De Michele <[email protected]>:
Dear all,
I am working with the 3 phase method (only from a few weeks) and I am trying to understand the BSDF file format and how the 3 phase method read it.
I have noticed that if I use the bsdf created with the command:
genBSDF -n 4 +f +b -geom meter material.rad blinds.rad > blinds.xml
the .xml file contain same geometrical dimension (height, width). In fact if I use the command:
pkgBSDF -s blinds.xml > blinds_pkg.rad
the output file contain the original geometry.
Instead if I use the BSDF created or contained in the database of WINDOW 7 these file do not contain a geometry.
With pkgBSDF I got an error.
My questions are:
2. I have understood that 3 phase method uses only the front transmission data [A. McNeil, Three-Phase Method tutorial] but in
an other discussion [ http://www.radiance-online.org/pipermail/radiance-general/2012-October/008969.html ] I have discovered that WINDOW and genBSDF use an opposite meaning of front and back, so the front transmission regards radiance or window meaning?And what part of the T matrix I have to use in the 3 phase method for the respective cases (WINDOW or genBSDF)?
Kind regards,
Giuseppe
Germán Molina L.
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445
Nota de Confidencialidad: Este mensaje incluído los archivos adjuntos son confidenciales y pueden contener informacion privilegiada protegida por ley. Si Ud. no es el destinatario, deberia abstenerse de copiarlo, distribuirlo, divulgarlo o usar la informacion contenida. Por favor, avise inmediatamente al emisor y borre este mensaje de su sistema. Los mensajes electronicos son susceptibles de ser cambiados, infectados o adulterados sin autorizacion. No asumimos responsabilidad alguna por ninguna clase de cambios o sus consecuencias. Usted debe estar informado que la compania puede hacer un seguimiento de sus mensajes electronicos y su contenido, gracias.
Confidentiality Notice: The information contained in this email message, including any attachment, is confidential and is intended only for the person or entity to which it is addressed. If you are neither the intended recipient nor the employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that you may not review, retransmit, convert to hard copy, copy, use or distribute this email message or any attachments to it. If you have received this email in error, please contact the sender immediately and delete this message from any computer or other data bank, Thank you.
A informação transmitida é confidencial e para conhecimento exclusivo do destinatário. Sua utilização, não autorizada, constitui crime passível de prisão. Todas as precauções possíveis foram tomadas para garantir que este e-mail não contenha vírus. Uma vez que nossa empresa não pode assumir responsabilidade por nenhuma perda ou dano causado por este e-mail ou de seus anexos, recomendamos que o destinatário utilize seus procedimentos de antivírus antes de qualquer uso.
Giuseppe De Michele
Germán Molina L.
Ingeniero Trainee
