BSDF orientation vector
Hi list, hi Greg,
I have a question concerning the BSDF "up-vector".
For e.g. a facade-mounted fenestration system the definition of the vector
is clear.
But what, if I have a BSDF defining the material properties and use this
BSDF to
simulate the BSDF of a daylighting system (i.e. curved specular lamellae)?
The comment in m_bsdf.c says that the "up-vector" together with the surface
normal
defines the local coordinate system. How exactly is that done??
Unfortunately I did
not have time yet to dig deeper into the BSDF-code to find that out...
David
The code is pretty simple. So long as the "up vector" is not parallel to the surface normal, it is used to orient the 0-degree azimuth position by projecting it into the plane of the surface normal at the ray intersection point. Make sense?
Date: May 15, 2012 12:20:15 AM PDT
Hi list, hi Greg,
For e.g. a facade-mounted fenestration system the definition of the vector is clear.
But what, if I have a BSDF defining the material properties and use this BSDF to
The comment in m_bsdf.c says that the "up-vector" together with the surface normal
defines the local coordinate system. How exactly is that done?? Unfortunately I did
David
Ok, perfect -- this is exactly what I hoped it to be!
Thanks for the fast response,
cheers,
David
2012/5/15 Gregory J. Ward <[email protected]>
point. Make sense?
> From: David Geisler-Moroder <[email protected]>
> Hi list, hi Greg,
vector is clear.
BSDF to
lamellae)?
surface normal
Unfortunately I did
> Cheers,
> David
