Browser-based horticultural lighting simulation on Radiance — photon-native PPFD, concentric-ring layout + basis-matrix solver — seeking technical feedback
Hi everyone,
I’ve been building a browser-based horticultural lighting simulation tool on top of Radiance and wanted to share the details here for feedback from people with more Radiance experience than I have. The tool compares three lighting system modes in a closed room CEA benchmark and is designed to make canopy uniformity comparisons easier to inspect.
The two things I’d most value scrutiny on are: (1) the photon-native solve pipeline and (2) the basis-matrix optimization approach for ring-wise power assignment — both described below. The source-model section is long but I’ve tried to be explicit about what is and isn’t claimed for each mode.
I’m happy to provide a link to the tool if the community is interested in messing around with it.
Source models
The three modes are not modeled the same way, and I want to be precise about the distinctions.
Modular LED surrogate (SMD mode)
A module-level physical surrogate — not a finished luminaire IES. Each module is a 150 mm × 150 mm PCB with a 120 mm × 120 mm emitting window carrying 145 LED sites in a fixed package mix: 52 warm-white, 52 cool-white, and 41 deep-red. The optical stack is modeled explicitly:
  • PMMA lid: 128 mm × 128 mm × 3 mm, n = 1.49, target transmission ~0.92
  • PTFE cavity liner: reflectance 0.97, thickness 0.508 mm, surrounding the emitting aperture
Electrical and optical baseline. At an estimated operating current of ~233 mA per string, nominal package electrical assumptions are 0.68 W for the white channels and 0.44 W for deep red. Per-channel PPE values are estimated at 2.73 µmol/J (warm-white), 2.81 µmol/J (cool-white), and 4.13 µmol/J (deep-red), giving a blended module base efficacy of ~3.00 µmol/J and a total PPF of ~269.6 µmol/s before optical cover and driver losses. After applying 92% PMMA transmission (without taking additional credit for PTFE photon recovery), estimated module output is ~248.0 µmol/s. With driver losses (HLG-185H-C700B or HLG-320H-C700B), estimated wall-plug efficacy is ~2.60–2.62 µmol/J.
Droop and thermal modeling. The engine computes continuous dynamic efficacy per module using component-level V-I (fC_vs_fV) and efficacy (ppe_vs_fC) characterization curves. The solver interpolates forward voltage and current for both the red and white channels at each driven current state, evaluating exact electrical power and relative PPE multiplier per channel. Non-system losses are applied as continuous multipliers: driver efficiency 0.96, wiring efficiency 0.99, and a continuous thermal derate coefficient scaled to module wattage to model junction temperature rise.
The engine applies a concentric ring-wise power assignment strategy (described in the layout and solver sections below) rather than a flat per-module wattage. No measured finished luminaire IES is claimed for this mode.
1000 W DE HPS surrogate
A physically parameterized surrogate for a broad distribution horticultural HPS fixture. Not presented as measured manufacturer photometry.
  • Envelope: 22.2 in × 9.7 in × 7.8 in
  • Lamp: horizontal double-ended arc-tube, approximated by an 8-face luminous prism
  • Reflector: explicit wide-reflector geometry with shallow gull-wing side panels, top cover, and end plates; RGB reflectance 0.92 / 0.91 / 0.87; semi-specular 0.16; roughness 0.03
  • Nominal output: 2050 µmol/s at 1050 W (~1.95 µmol/J)
Lamp-level source output is set slightly above fixture-level emitted output to absorb reflector losses. Layout is by nominal coverage footprint (4 ft × 4 ft or 5 ft × 5 ft grid) rather than exact envelope packing. Mounting height: 36 in.
Conventional LED (IES-composed mode)
This mode is different in kind from the two above. It constructs a 6-bar fixture by repeating a single bar-level IES source six times across an explicit fixture envelope. It is not a physically parameterized surrogate and does not claim a measured one-piece horticultural luminaire IES for the assembled fixture.
  • Fixture envelope: 47.75 in × 43.44 in; bar envelope 47.75 in × 4.46 in × 1.56 in
  • Bar center-to-center spacing: ~7.80 in
  • IES archetype: bundled conventional.ies, a 4 ft strip-light style photometric file reporting ~8159.6 lm and 46 W per bar
  • Lumens-to-photons conversion: 0.015 µmol/s per lumen (configurable scalar)
  • ies2rad normalization: Radiance luminous-efficacy constant of 179 lm/W
  • Fixture-level PPF target: 2200 µmol/s (~366.7 µmol/s per bar)
  • PPE assumption for electrical reporting: ~2.7 µmol/J
This preserves directional bar-driven canopy structure and spacing sensitivity. The main modeling limitation is that the bar-level IES is a strip-light archetype rather than a measured source for this fixture class, and the lm → µmol/s conversion uses a single broadband scalar rather than a spectrally resolved model.
PPFD methodology — photon-native Radiance solve
Rather than running a standard lux solve and applying a post-hoc lm → µmol/s correction, the engine normalizes all emitters into µmol units before calling rtrace. Because emitters are authored with equal RGB values representing photon flux, the three returned channels from rtrace are treated as already being in photon units, and scalar PPFD is recovered by:
\text{PPFD} = \frac{R + G + B}{3}
Source authoring differs by mode:
  • SMD and HPS modes: light materials are written directly in µmol/s/sr/m² with equal RGB values.
  • Conventional LED mode: IES lumens are converted to photons via the 0.015 µmol/s per lumen factor, then normalized through the 179 lm/W ies2rad constant, so the scaled source is traced purely as a photon emitter.
The main approximation here is in the IES path: a single broadband scalar replaces a wavelength-resolved spectral model. I’d welcome feedback on whether this is an acceptable approximation for comparative canopy uniformity work, or whether it introduces a systematic error I should be treating differently.
Layout framework
Concentric ring placement
The modular LED system uses a concentric ring layout that serves two purposes: it determines both physical module placement and the control zone structure used by the optimization solver. The room footprint is mapped to an integer module grid of width N_x and height N_y after snapping physical dimensions to the module mechanical pitch (152.4 mm × 165.0 mm).
Square mode begins with a fixed X-pattern centerpiece of n_0 = 5 modules. For t concentric rings, each ring j contains r_j = 4j + 4 modules, giving a total module count of:
M_{\square}(t) = 5 + 2t^2 + 6t
This recurrence is unbounded, enabling arbitrarily large square layouts while preserving the same ring-indexed control structure.
Rectangular extension handles non-square footprints (N_x \geq N_y) by building around a central linear base strip of length n modules. With t = (N_y - 1)/2 rings stacked above and below, ring j contains r_j = 2n + 4j - 2 modules, and the outermost row length sets the required base-strip length as n = N_x - N_y + 2. Total module count:
M_{\mathrm{rect}}(n,t) = n(1 + 2t) + 2t^2
Tiling. When a target room exceeds the size of a single square cell, the generator tiles square cells and introduces a minimal rectangular extension only when required by the room aspect ratio, connected by a single centralized linear strip. Square sub-arrangements are preferred because square zoning produces more symmetric control behavior than rectangular extensions. The resulting module map is realized physically using a small family of fixture types (X-pattern, linear sections, corner sections) while preserving the generated placement and ring zoning structure.
All arrangements are centered inside the usable room span after the outer wall inset and mechanical footprint allowances.
Basis-matrix solver and optimization
The concentric-zone power assignment is determined by a Radiance-based linear superposition approach. Rather than re-rendering the full scene for every candidate weight combination, the solver first constructs a response basis from ring-isolated simulations.
Basis construction
For a layout with K concentric control rings sampled at n sensor locations, each ring is rendered in isolation at a defined unit drive level while all other rings are off. The resulting PPFD values across the sensor grid form a column vector. Collecting these columns yields a response matrix A \in \mathbb{R}^{n \times K}. For any ring-weight vector w \in \mathbb{R}^{K}, the predicted canopy-plane field is:
p = Aw
Once A has been generated for a given room geometry and layout, candidate ring weights can be evaluated rapidly without repeated full ray-trace calls.
Optimization formulation
The solver minimizes spatial deviation from a user-defined target mean PPFD \mu subject to control bounds and a mean-constraint:
\min_{w} |Aw - \mu\mathbf{1}|_2^2 + \lambda_s |Dw|_2^2 + \lambda_r |w|_2^2
subject to:
\frac{1}{n}\mathbf{1}^\top Aw = \mu, \qquad w_{\min} \leq w \leq w_{\max}
Here D is a first-difference matrix penalizing abrupt ring-to-ring transitions, and \lambda_s, \lambda_r are optional smoothness and ridge regularization coefficients. In the default workflow, the variance minimization term is dominant and regularization is used only as needed to suppress non-physical weight oscillation. Solutions that fail to satisfy the mean constraint within the specified tolerance are rejected.
The ring-wise power assignment produced by the solver feeds directly into the per-module efficacy and droop calculations described in the SMD source model section above.
Room model and benchmark setup
Simulations were run in a closed six-surface room: four walls, ceiling, and floor.
  • Walls and ceiling: diffuse RGB 0.90 / 0.90 / 0.90, specularity 0.04, roughness 0.00 (intended to approximate panda film)
  • Floor: diffuse reflectance 0.10 to reduce unrealistic floor-bounce uplift
  • Canopy sensor plane: z = 0.005 m, physically adaptive rectangular grid, target sensor spacing 0.25 m with minimum grid counts enforced for smaller rooms
Mounting heights: 18 in for the SMD and conventional LED modes, 36 in for the DE HPS mode, reflecting typical deployment distances for each system class.
Convergence study (12 ft × 12 ft room, SMD mode)
I ran a three-preset convergence study targeting 1000 µmol/m²/s mean PPFD.
Preset -ab -ad -as -aa -ar -dj -ds -dt -dc -dr -lr -lw
Standard 3 512 128 0.22 48 0.35 0.40 0.08 0.50 1 6 2e-4
Quality 5 2048 512 0.12 96 0.65 0.20 0.03 0.85 3 12 5e-5
Rigorous 6 4096 1024 0.08 128 0.70 0.15 0.02 0.90 4 16 2e-5
PPFD uniformity metrics are essentially converged across all three presets (CV spread of ~0.22 percentage points). The more notable result is that Standard underreports required electrical input by roughly 10% relative to Quality and Rigorous — likely attributable to the lower -ab and -dc values and higher -ds accepting more direct sampling approximation. The precomputed bundles in the web application currently use the Standard preset, but based on this finding I may need to recompute the data bundles through the Quality preset.
Preset Watts in Mean PPFD Min PPFD Max PPFD CV DOU
Standard 4713.1 1000.00 946.66 1034.26 1.60% 98.40%
Quality 5228.7 1000.20 952.66 1036.79 1.47% 98.53%
Rigorous 5173.4 1000.32 952.41 1031.60 1.38% 98.62%
Questions for the community
  1. Does the photon-native solve approach look sound? Is the IES-path broadband scalar approximation a more significant methodological gap than I’m treating it as for comparative uniformity work?
  2. Do the convergence parameters and Quality preset selection look reasonable? Any settings I should be revisiting?
  3. Are the reflectance and room model assumptions fair for a closed room horticultural benchmark, or are there common pitfalls with this geometry worth guarding against?
  4. Is the source modeling distinction between the physically parameterized surrogates and the IES-composed mode described clearly and honestly enough, or does something read as overclaiming?
  5. Does the basis-matrix superposition approach — rendering each ring in isolation then combining — introduce any Radiance-specific issues I should be aware of? I’m relying on linear superposition holding at the zoning level given the predominantly diffuse room surfaces, but I’d welcome scrutiny on that assumption.
  6. Any other Radiance-specific pitfalls to watch for in a comparative workflow across geometrically and optically heterogeneous source models?
Since horticultural lighting is a less common Radiance use case, I’d especially appreciate feedback on any assumptions that look off.
Thanks for reading, and special thanks to Greg Ward / this community for creating such a brilliant tool.
Hi Austin,
Welcome to the forum!
I don’t see a particular problem with altering units to photon flux rather than radiant flux – the two are basically equivalent. So long as you aren’t introducing any errors around solid angle integrals, which I’m not quite able to discern from your description, you should be fine.
The only thing I noticed is that you could optimize your matrix approach using rcontrib or rfluxmtx, which are specifically optimized for this type of analysis.
I’m hoping others with more knowledge of horticulture will offer their insights. This is rather out of my domain.
P.S. If your scene has color, either spectral or RGB values that are not gray, then computing photon counts from watt-based units should provide for the different mole/joule factor at different wavelengths.
Thank you for the warm welcome and the thoughtful reply. It’s genuinely appreciated.
I followed up on your suggestion to try rcontrib in modifier-tracking coefficient mode (-M) for building the ring-isolated basis matrix. On smaller, more direct-dominated cases (-ab 0 -aa 0 -u+ -dc 1.0 -dj 0.60 -ds 0.08 -dt 0 -dr 0 -lr 0 -lw 1e-5) it performed well: the resulting coefficients stayed numerically close to my legacy ring-isolated rtrace workflow and scaled better with higher thread counts.
On larger, indirect-heavy cases (higher -ab, more interreflections from the high-reflectance panda-film surfaces), however, the pure rcontrib approach became significantly slower and less competitive. After some investigation, my current understanding is that stock rcontrib -M does not use ambient interpolation/cache reuse the way the repeated rtrace path does. That seems to leave the repeated isolated rtrace runs with the main performance advantage in those cases.
Does that match how you see the design of rcontrib in this kind of grouped-source (multiple discrete control zones) basis problem?
On the photon-native side, your P.S. was helpful. The IES-composed mode uses a single broadband 0.015 µmol/s per lumen scalar as a neutral/cool white LED approximation, informed by published white-light PPFD conversion factors. I treat it strictly as a comparative canopy-uniformity tool rather than an absolute or spectrally resolved claim.
Thanks again for taking the time to look at the post.
Austin
Hi Austin,
Yes, rcontrib and rfluxmtx cannot use the ambient cache the way rtrace and other rendering tools can. This is because it’s impossible to disentangle the contributions with a cache, which loses the required information.
Instead, these tools use something called “Monte Carlo Path Tracing” or MCPT, which is a well-established computational method that doesn’t rely on an irradiance cache. Instead, it sends out many initial diffuse rays on the first bounce, then a few or perhaps only 1 ray per subsequent bounce. The method is noiser but less biased than an irradiance cache, and in complex environments can sometimes perform even better. In simple environments, you may pay a higher price, but it’s important not to set the rendering parameters the same for MCPT as what worked for rtrace.
Generally speaking, you want the initial bounce to generate enough secondary rays that the noise is kept manageably low. If you are computing individual point irradiances (or photon counts) over a grid, then you’ll want to send a few thousand initial rays, so set -ad 2048 or higher. (You can get by with many fewer samples if you are computing many pixels for an image.) Then, set the -lw to 1/2048 or less – I often use half to one quarter of the reciprocal of the -ad setting. The insures that all the first-bounce rays happen while deeper bounces are curtailed to a few rays. Set -ab to whatever you like – the calculation cost should be roughly proportional to the number of bounces you set, which is better performance than you typically get with an ambient cache. (Be sure that the -lr setting is negative and greater magnitude than the -ab setting to enable Russian roulette.)
The other parameters are less important, and should probably be left at their defaults. Certain parameters like -dt, -aa and -as get overridden, anyway, to enable proper contribution tracking.
If your performance isn’t paying off with rcontrib and the recommended settings, then there’s no major reason to prefer it over the rtrace method you’ve already worked out.
P.S. Forgot to mention you’ll probably want the rcontrib -V+ option to take any IES distributions into account. Otherwise, it doesn’t count the value from the LED sources.
Thank you for the detailed follow-up on rcontrib and the MCPT parameter guidance. I tested an MCPT-oriented rcontrib configuration based on your recommendations, specifically higher -ad, -lw tied to the reciprocal of -ad, and negative -lr for Russian roulette, and benchmarked it against both my baseline rcontrib settings and my existing repeated isolated rtrace path.
The exact settings used were:
rtrace Standard
-ab 3 -ad 512 -as 128 -aa 0.22 -ar 48 -dj 0.35 -ds 0.40 -dt 0.08 -dc 0.50 -dr 1 -lr 6 -lw 2e-4
rtrace Quality
-ab 5 -ad 2048 -as 512 -aa 0.12 -ar 96 -dj 0.65 -ds 0.20 -dt 0.03 -dc 0.85 -dr 3 -lr 12 -lw 5e-5
rcontrib Baseline Standard
-I+ -V+ -ab 3 -ad 512 -as 128 -ar 48 -aa 0.22 -dc 0.5 -dj 0.35 -ds 0.4 -dt 0.08 -dr 1 -lr 6 -lw 2e-4
rcontrib Baseline Quality
-I+ -V+ -ab 5 -ad 2048 -as 512 -ar 96 -aa 0.12 -dc 0.85 -dj 0.65 -ds 0.2 -dt 0.03 -dr 3 -lr 12 -lw 5e-5
rcontrib MCPT Standard
-I+ -V+ -u+ -ab 3 -ad 2048 -lr -6 -lw 2.44e-4
rcontrib MCPT Quality
-I+ -V+ -u+ -ab 5 -ad 2048 -lr -8 -lw 2.44e-4
The MCPT-oriented runs were not intended as strict one-variable comparisons against the baseline presets, since they also include the higher -ad and corresponding -lw / -lr changes implied by the MCPT approach.
12 ft × 12 ft, 6 rings, 441 sensors, Standard preset, 12 threads
Backend Wall time (s) RMSE vs rtrace (µmol/m²/s) Final CV
rtrace 37.6 0.00 1.92%
rcontrib baseline 72.8 9.96 1.86%
rcontrib MCPT 265.7 11.84 1.88%
12 ft × 12 ft, 6 rings, 441 sensors, Quality preset, 12 threads
rtrace 492.0 0.00 1.75%
rcontrib baseline 356.6 8.60 1.83%
rcontrib MCPT 374.2 9.94 1.84%
20 ft × 20 ft, 10 rings, 576 sensors, Quality preset, 12 threads
rtrace 1133.0 0.00 1.37%
rcontrib baseline 1761.9 8.82 1.35%
rcontrib MCPT 1873.4 10.81 1.49%
In this particular ring-zoned workflow, rcontrib did not turn out to be a clear improvement over the cached rtrace approach. It was slower in most cases and produced higher reconstructed-field RMSE in all runs. My current plan is to retain rtrace as the default basis path, with rcontrib available as an alternate backend for cases where the cache-free MCPT behavior might still be preferable.
Worth having tested. I’m always looking for ways to improve my Radiance workflow. Thanks for the suggestion.
Austin
I should have asked before – what does “CV” stand for? I’m not sure I know this metric.
So long as you’re confident that the rtrace calculations are accurate. There is a bias to under-estimate results with the default -av 0 0 0 setting because the remainder of uncounted bounces is left off. The ultimate test would be MCPT with something link -ab 20 -lr -30, though in a case where direct lighting dominates, it shouldn’t make much difference.
Thank you, that is very helpful.
CV refers to coefficient of variation: the standard deviation divided by the mean of the PPFD values across the sensor grid. PPFD here is photosynthetic photon flux density, meaning the incident photosynthetic photon flux at the canopy plane, reported in µmol m⁻² s⁻¹. I’m using CV simply as a uniformity metric for the sampled PPFD field.
I’m not fully confident yet that my rtrace results are as accurate as they should be. I’m currently preparing this work for a manuscript submission to Lighting Research & Technology, so it is important to me to be confident that the reported results are numerically defensible.
Your note about the underestimation bias associated with the default -av 0 0 0 behavior is especially useful. I’ll revisit that part more carefully. I’ll also probably try the more extreme MCPT-style test you suggested (-ab 20 -lr -30) when I have a bit of time, if only out of curiosity to see how much it changes things.
Thanks again. I really appreciate the guidance.
Austin
Hey everyone, just wanted to bump the thread with a link to the actual tool described in the OP, since I feel a little silly for never including it after writing such a detailed post about it lol.
Here it is:
If you run into any bugs or have any feedback, I’d really appreciate hearing it here.
My next Radiance project is an attempt to achieve similar uniformity results in greenhouses with supplemental LED lighting. That is a much trickier problem, but I have a couple of ideas I’m excited to test. Time will tell, and Radiance will definitely be the tool I use to explore it.
Best regards,
Austin
