better results on genBSDF
Dear list,
I am using genBSDF to get the BTDF of a shading system, comparing it to an
analytical model using the radiosity method. No surprise, the calculations
seem to be really good, nevertheless, there are some important differences
on directly transmitted (specular) calculations. I am using the following
parameters:
genBSDF -n 4 -c 4000 -r '-ab 4 -ad 512 -as 0 -aa 0 -ds 0.01 -dj 0'
material.mat geometry.rad > ../TMX/file.xml
I tried modifying the -c option, but it did not show any improvements, so I
stayed on 4000. Any suggestions from gurus?
THANKS
German
Hi German!
an analytical model using the radiosity method. No surprise, the
calculations seem to be really good, nevertheless, there are some
important differences on directly transmitted (specular) calculations. I
Why do you think that "an analytical model using the radiosity method"
results in "better" results than raytracing does for specular transmission?
Hi Lars,
considering that the specular transmission is that light that does not
touch any surface, the analytical solution would be the exact one (am I
right?). Also, HERE<http://windows.lbl.gov/materials/optics/Bidirectional%20Properties%20of%20Slat%20Shading.pdf&gt;,
those results were compared agains TracePro, and the results of the forward
ray-tracing gave, basically, the same results as the model I am using.
THANKS
German
2013/2/16 Lars O. Grobe <[email protected]>
Hi German!
The genBSDF program produces a limited resolution matrix representation using the options you've given. This is appropriate if you want to use it with WINDOW (although I think some modifications to the output are still required) or if your material is fairly diffusing. It will not resolve the direct peak to anything finer than 10 degrees, which is the resolution of the full Klems matrix basis. Some spreading of the direct is unavoidable.
You can improve upon this using the tensor tree formulation by setting the -t3 or -t4 option. If your system produces an isotropic distribution (i.e., you can rotate the system about its center with no change to the output), you can try "genBSDF -t3 6" or so. In the more general case, you can use "genBSDF -t4 6", which will resolve the direct component to within a few degrees. You can increase to "-t4 7" to get twice the resolution, but you'll have to increase the -c parameter as well, and I can't predict when the calculation will finish.
The real solution is to incorporate and employ the actual system geometry using the proxy method described near slide 7 in my 2011 workshop presentation:
  http://www.radiance-online.org/community/workshops/2011-berkeley-ca/presentations/day2/GW5_BSDFFirstClass.pdf
Date: February 16, 2013 11:49:09 AM PST
Hi Lars,
considering that the specular transmission is that light that does not touch any surface, the analytical solution would be the exact one (am I right?). Also, HERE, those results were compared agains TracePro, and the results of the forward ray-tracing gave, basically, the same results as the model I am using.
THANKS
German
Hi German!
Date: February 16, 2013 7:06:26 AM PST
Dear list,
I am using genBSDF to get the BTDF of a shading system, comparing it to an analytical model using the radiosity method. No surprise, the calculations seem to be really good, nevertheless, there are some important differences on directly transmitted (specular) calculations. I am using the following parameters:
genBSDF -n 4 -c 4000 -r '-ab 4 -ad 512 -as 0 -aa 0 -ds 0.01 -dj 0' material.mat geometry.rad > ../TMX/file.xml
I tried modifying the -c option, but it did not show any improvements, so I stayed on 4000. Any suggestions from gurus?
THANKS
German
Thanks Greg and Lars!
I intend to use these BSDFs for annual simulations (three-phase method). Is
it possible to use the Tensor-tree implementation on that? I think I can
live with the claimed error anyway...
THANKS AGAIN
Germán
2013/2/16 Greg Ward <[email protected]>
presentation:
*Date: *February 16, 2013 11:49:09 AM PST
Hi Lars,
THANKS
German
Hi German!
transmission?
*Date: *February 16, 2013 7:06:26 AM PST
Dear list,
parameters:
THANKS
German
The 3-phase method is restricted to matrix (Klems) BSDFs for the time being. A more sophisticated method is in the works, but won't be ready for several months.
Date: February 16, 2013 12:27:02 PM PST
I intend to use these BSDFs for annual simulations (three-phase method). Is it possible to use the Tensor-tree implementation on that? I think I can live with the claimed error anyway...
THANKS AGAIN
Germán
Hi Lars,
THANKS
German
Hi German!
Dear list,
THANKS
German
German,
Did you consider that genBSDF integrates over the incident Klems patch
while radiosity method used in window 6 just uses the center of the patch
for incident energy?
It is easy to modify genBSDF to use the ceter of the Klems patch by
removing a couple of the random variables in incident ray generation.
Andy
several months.
*Date: *February 16, 2013 12:27:02 PM PST
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
I
transmission?
Dear list,
THANKS
German
Andy, indeed I did not do that; probably that is what causes the problem...
Could you explain me how to do that?
THANKS
2013/2/19 Andrew McNeil <[email protected]>
German,
Andy
several months.
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
to
calculations. I
transmission?
Dear list,
THANKS
German
actually, now that you mention it, I think that the errors I thought were
caused by the borders can be explained by what you say.
2013/2/19 Germán Molina Larrain <[email protected]>
THANKS
German,
Andy
several months.
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
to
calculations. I
transmission?
Dear list,
THANKS
German
I think all you need to do is change lines 350 and 351 of genBSDF.pl so
they look like this:
Kazi = 360*DEGREE * Kcol / Knaz(Krow);
Kpol = DEGREE * (0.5*Kpola(Krow) + 0.5*Kpola(Krow-1));
(this only changes it for Klems BSDF generation)
Andy
On Wed, Feb 20, 2013 at 5:44 AM, Germán Molina Larrain <[email protected]>wrote:
problem...
THANKS
German,
Andy
several months.
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
it to
calculations. I
transmission?
Dear list,
THANKS
German
Ok, I will try those changes, and let you know my results.
THANKS ANDY!
2013/2/20 Andrew McNeil <[email protected]>
Andy
problem...
THANKS
German,
Andy
several months.
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
it to
calculations. I
method"
transmission?
Dear list,
THANKS
German
Andy,
your suggestion worked perfectly.
THANKS
2013/2/20 Germán Molina Larrain <[email protected]>
THANKS ANDY!
Andy
were caused by the borders can be explained by what you say.
problem...
THANKS
German,
Andy
several months.
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
it to
calculations. I
method"
transmission?
Dear list,
THANKS
German
Great! Glad it all works out.
On Thu, Feb 21, 2013 at 10:48 AM, Germán Molina Larrain <[email protected]>wrote:
Andy,
THANKS
THANKS ANDY!
Andy
problem...
THANKS
German,
patch while radiosity method used in window 6 just uses the center of the
patch for incident energy?
Andy
THANKS AGAIN
Germán
presentation:
Hi Lars,
THANKS
German
Hi German!
comparing it to
calculations. I
method"
transmission?
Dear list,
THANKS
German
