Dear Community
I am trying to determine a maximum illum value within a picture file then print the result if it is above a certain value. Here is where I am at the moment:
maxim=$(pextrem -o 9.pic | rcalc -e '$1=($3*0.265+$4*0.670+$5*0.065)*179' | total -u)
echo $maxim
if [ "$maxim" -gt 15000 ] ; then
pextrem -o 9.pic | rcalc -e '$1=($3*0.265+$4*0.670+$5*0.065)*179' total -u > 9.dat
fi
done
The problem: I keep getting the : integer expression expected warning. As far as I can see, $maxim is an integer as shown from the echo expression. Therefore I don't understand what I'm doing wrong here. Any pointers will be greatly appreciated.
Dan
Hi Dan,
it is easier then that. You can use the special variable cond in rcalc
to decide whether any output is to be generated or not.
pextrem -o 9.pic | rcalc -e 'illummax=($3*0.265+$4*0.670+$5*0.065)*179'
-e 'cond=if(illummax-15000,1,-1)' -e '$1=illummax' | total -u > 9.dat
does the job (ok, you will get an empty file 9.dat if the illuminance
value is below 15000).
Thanks for the speedy reply Lars. That's a tidy way of doing it but I still need to figure where my original expression is wrong as I also need to run some further expressions to the file if the result is true. Looking a bit more closely at the result it appears the expression creates a tab and extra line to the value...I wonder if this is why the script thinks the expression is not an integer?!
From: [email protected] [mailto:[email protected]] On Behalf Of Lars O. Grobe
Sent: 22 July 2009 18:47
Subject: Re: [Radiance-general] Bash problems
Hi Dan,
it is easier then that. You can use the special variable cond in rcalc to decide whether any output is to be generated or not.
does the job (ok, you will get an empty file 9.dat if the illuminance value is below 15000).
Hi Dan,
It looks like you need a "|" in your second call to pextrem (before total). However since you have already calculated the value for maxim, why not just echo $maxim to 9.dat? Such as:
echo $maxim
echo $maxim > 9.dat
fi
done
Dan Fitzpatrick wrote:
Dear Community
echo $maxim
fi
done
Dan
# Jack de Valpine
Hi Jack,
Many tanks for the response. You're right, I did miss the "pipe" before total in the second call. However, the -gt element still thinks I need to express an integer when in fact it should be exactly that.
Dan
From: [email protected] [mailto:[email protected]] On Behalf Of Jack de Valpine
Sent: 22 July 2009 19:17
Hi Dan,
echo $maxim
echo $maxim > 9.dat
fi
done
Hi Dan,
I haven't really been following this thread, but did you try the "floor()" function around your rcalc expression to guarantee you get an integer result?
Date: July 22, 2009 10:29:11 AM PDT
Dear Community
echo $maxim
fi
done
Dan
That seems to be it. Thank you so much.
-Dan
From: [email protected] [mailto:[email protected]] On Behalf Of Greg Ward
Sent: 22 July 2009 19:37
Hi Dan,
an integer result?
