If you are referring to solar collectors on the roof, there are three different recommended tilt angles as measured from the horizontal:
If you would like to use the system mainly in the winter, tilt it around (Latitude + 10 deg)
If your system is used mainly in the summer, tilt it around (Latitude - 10 degrees)
If you would like to use the system year-round, tilt it around latitude degrees
The system is not very sensitive to vertical rotations or optimization, unless your cloud cover occurs at specific times.
If you need more info, use software from lambdares.com, zemax.com or breault.com, but I believe that even those would better be used for the visible range. Maybe you can find this info on ther web sites.
Martin
Martin Moeck, Ph.D., Assistant Professor
Pennsylvania State University
Department of Architetcural Engineering
http://www.engr.psu.edu/ae
Von: jean brange [mailto:[email protected]]
Gesendet: Sa 20.07.2002 06:05
An: [email protected]
Cc:
Betreff: [Radiance-general] solar pannel calculation with radiance ?
I am working on a design for my house
I am planning a solar heated floor, I am getting contradictory
informations on the best orientation of the panels so I wondered if I
could use radiance to model them and make a simultaion of the infrared
absorbtion of a panel. had any one already done such thing ?
regarding IR absorbtion by the panel I have read that the IR rays once
passed through the glass are partly absorbed, partly reflected but that
the reflection is not completly reemited through the glass but refracted
to the black side of the panel. would a glass material take this in
count or do I have to use a a dielectric and an interface or a BDRTF ?
Jean Brange_________________AFNET____________________0662401961
____Association_Française_des_utilisateurs_du_Net___http://www.afnet.fr____
