When I was following the tutorial "The Three-Phase Method for Simulating Complex Fenestration with Radiance", I could not run the command "gensky 1 12 11|genskyvec -m 1>skyvec_1-21-11_1.skv"(p3) because there is no genskyvec.exe file in my Radiance/bin folder.
Instead of genskyvec.exe, I found genskyvec.pl. Additionally, I found some command is in perl formal, not in exe format.
Can anyone tell me why some command is writtern by perl file?
And also are there any document how I can use these perl file through command prompt?(ex. What is the argument etc)
Thank you.
Katsuya
There are a few Radiance programs that are not compiled C code but rather
are interpreted programs, generally written in Perl (but a few
csh dinosaurs remain). In order to use them, you need to have Perl
installed, and properly configured. Once this is complete, that
perl program will execute just the same as any regular Radiance executable.
The man page for genskyvec is here:
http://radsite.lbl.gov/radiance/man_html/genskyvec.1.html
On Mon, Nov 7, 2016 at 8:04 PM, Katsuya Obara <[email protected]> wrote:
When I was following the tutorial “The Three-Phase Method for Simulating
Complex Fenestration with Radiance”, I could not run the command “gensky 1
12 11|genskyvec –m 1>skyvec_1-21-11_1.skv”(p3) because there is no
Thank you.
Katsuya
Hi Katsuya,
You can find Windows exe files of all the Radiance Perl scripts on my web site:
http://www.jaloxa.eu/resources/radiance/radwinexe.shtml
just drop the exe files into the Radiance bin folder.
Kind regards
Axel
On 8 November 2016 at 03:04, Katsuya Obara <[email protected]> wrote:
Thank you.
Katsuya
Hi Axel,
Thank you for your reply.
You are doing so great work!
Following your instruction, I could run all the exe file except for genskyvec.exe.
When I tried to run genskyvec, I get following error message.
"The process cannot access the file because it is being used by another process."
Do you have any idea what is causing this error?
Thank you.
Katsuya
Sent: Tuesday, November 08, 2016 5:44 PM
Subject: Re: [Radiance-general] are there any document for perl file included in Radiance/bin folder?
Hi Katsuya,
Kind regards
Axel
Simulating Complex Fenestration with Radiance”, I could not run the
command “gensky 1
Thank you.
Katsuya
Electronic mail messages entering and leaving Arup business systems
Hi Katsuya,
I've never seen this error message, but it sounds like some Windows
file locking thing. Do you have the file you're trying to process
open in a text editor?
Cheers
Axel
On 9 November 2016 at 01:52, Katsuya Obara <[email protected]> wrote:
Hi Axel,
Thank you.
Katsuya
Hi Katsuya,
Windows Binaries
Kind regards
Axel
command “gensky 1
Thank you.
Katsuya
Hi Axel, Greg, Katsuya,
I get the same error on Windows when using dctimestep. Here's a sample
output:
D:\nljones\models\Reference\GH>rcontrib -version
NREL 5.0.a.12 (by googs 2016.10.04) based on RADIANCE 5.0 Official Release
by G. Ward
D:\nljones\models\Reference\GH>perl W:\Radiance\src\util\genBSDF.pl
windowBSDF.rad 1>ReferenceGH_BTLAB-16_ab8_ad50000_lr10_lw.00002.xml
Recover using: W:\Radiance\src\util\genBSDF.pl -recover
C:\Users\nljones\AppData\Local\Temp\genBSDF.v4UOj7
D:\nljones\models\Reference\GH>dctimestep
ReferenceGH_BTLAB-16_ab8_ad50000_lr10_lw.00002.vmx
ReferenceGH_BTLAB-16_ab8_ad50000_lr10_lw.00002.dmx
ReferenceGH_BTLAB-16_ab8_ad50000_lr10_lw.00002.smx
1>ReferenceGH_BTLAB-16_ab8_ad50000_lr10_lw.00002_0_tpm.dat
C:\Users\nljones\AppData\Local\Temp\genBSDF.v4UOj7\phase.txt - The process
Note that for the perl scripts, I'm referencing them from my clone of the
NREL git repo, so they should be up to date.
I'm not sure if the messages indicate that anything bad has happened, as
dctimestep is still generating output.
Nathaniel
On Wed, Nov 9, 2016 at 4:33 AM, Axel Jacobs <[email protected]> wrote:
Hi Katsuya,
Cheers
Axel
> Hi Axel,
genskyvec.exe.
process."
> Thank you.
> Regards,
> Katsuya
> From: Axel Jacobs [mailto:[email protected]]
> Hi Katsuya,
web site:
> Windows Binaries
> Kind regards
> Axel
> On 8 November 2016 at 03:04, Katsuya Obara <[email protected]> > wrote:
>> Hi all,
>> command “gensky 1
>> Thank you.
>> Regards,
>> Katsuya
>> [email protected]
> [email protected]
> [email protected]
Hi Katsuya,
I suggest to follow the advice from Rob. I usually run the 3-phase method
on Windows OS using the last Radiance release (5.x.x) and it works fine
with the perl program. Just install the perl interpreter (I use this one
<http://strawberryperl.com/>\) and run the command for genskyvec with the
.pl extention, like:
gensky 1 12 11|genskyvec.pl –m 1>skyvec_1-21-11_1.skv
best,
Giuseppe
2016-11-09 2:52 GMT+01:00 Katsuya Obara <[email protected]>:
Hi Axel,
genskyvec.exe.
process."
Thank you.
Katsuya
Hi Katsuya,
site:
Windows Binaries
Kind regards
Axel
> Hi all,
> command “gensky 1
> Thank you.
> Regards,
> Katsuya
> [email protected]
*Giuseppe De Michele*
Hi Giuseppe,
Well, I am using Strawberry perl (I've also tried other perl interpreters),
and I am using the latest Radiance release (5.0.a.12), and I am still
having this issue.
Nathaniel
On Wed, Nov 9, 2016 at 9:25 AM, Giuseppe De Michele <[email protected]> wrote:
Hi Katsuya,
best,
Giuseppe
Hi Axel,
genskyvec.exe.
process."
Thank you.
Katsuya
Hi Katsuya,
site:
Windows Binaries
Kind regards
Axel
On 8 November 2016 at 03:04, Katsuya Obara <[email protected]> >> wrote:
> Hi all,
> command “gensky 1
> Thank you.
> Regards,
> Katsuya
> [email protected]
Hi Giuseppe,
Thank you for your explanation.
When I tried to run following your instruction, I could run without problem.
Thank you!
Katsuya
Sent: Wednesday, November 09, 2016 10:32 PM
Hi Giuseppe,
Well, I am using Strawberry perl (I've also tried other perl interpreters), and I am using the latest Radiance release (5.0.a.12), and I am still having this issue.
Nathaniel
On Wed, Nov 9, 2016 at 9:25 AM, Giuseppe De Michele <[email protected]<mailto:[email protected]>> wrote:
Hi Katsuya,
I suggest to follow the advice from Rob. I usually run the 3-phase method on Windows OS using the last Radiance release (5.x.x) and it works fine with the perl program. Just install the perl interpreter (I use this one<http://strawberryperl.com/>\) and run the command for genskyvec with the .pl extention, like:
gensky 1 12 11|genskyvec.pl<http://secure-web.cisco.com/11h2b4hjqlKVj0HetF9cYfs-QdQKgcshHvH_IXss6JZX33B9gmeErbc-TZuqCuEMLfpFNCa3y_pUfx5yBvFE8Lpy990aQsAzFEptiWY8p2Ik0V7heu3eNFLYD5jHE_YtSCT1PyGvlapRMNNo8NU9oyxZMDI4iSHd5Yt0eV9TLBGFnpnqKE6kaKAm1CAhQXn2F8DSgAGxeWGJwpye-ryNnBqWFYwkNHXaKYoeuMbBkpd4/http%3A%2F%2Fgenskyvec.pl> –m 1>skyvec_1-21-11_1.skv
best,
Giuseppe
2016-11-09 2:52 GMT+01:00 Katsuya Obara <[email protected]<mailto:[email protected]>>:
Hi Axel,
Thank you.
Katsuya
From: Axel Jacobs [mailto:[email protected]<mailto:[email protected]>]
Hi Katsuya,
Kind regards
Axel
On 8 November 2016 at 03:04, Katsuya Obara <[email protected]<mailto:[email protected]>> wrote:
command “gensky 1
Instead of genskyvec.exe, I found genskyvec.pl<http://secure-web.cisco.com/11h2b4hjqlKVj0HetF9cYfs-QdQKgcshHvH_IXss6JZX33B9gmeErbc-TZuqCuEMLfpFNCa3y_pUfx5yBvFE8Lpy990aQsAzFEptiWY8p2Ik0V7heu3eNFLYD5jHE_YtSCT1PyGvlapRMNNo8NU9oyxZMDI4iSHd5Yt0eV9TLBGFnpnqKE6kaKAm1CAhQXn2F8DSgAGxeWGJwpye-ryNnBqWFYwkNHXaKYoeuMbBkpd4/http%3A%2F%2Fgenskyvec.pl>\. Additionally, I found
Thank you.
Katsuya
Giuseppe De Michele
