Approximating the gross daylight flux throughvenetian blinds.
Yes, that`s what I meant. Now I understand the problem. I just thought it
would save some calculation of the interreflections between slats, but
surely that`s not significant.
Thank you for the clarification.
Santiago
[mailto:[email protected]]On Behalf Of
Greg Ward
Sent: Saturday, October 30, 2004 4:16 AM
Subject: Re: [Radiance-general] Approximating the gross daylight
I haven't read this paper -- thanks for pointing it out. I know that
Marilyne Anderson is continuing her measurement work now that she's at
MIT.
Regarding your suggestion with the BRTDfunc, if I understand you
correctly, you are suggesting that it might be possible to simulate the
apprearance of slats in the model. I agree, but I think that might
defeat the purpose of using such a model, as we would be reintroducing
irregularities in the light coming through that would then require
heavier sampling to resolve. That is the current problem with venetian
blind models -- it's not that Radiance can't handle the complex
geometry, quite the contrary. It is simply that the slats themselves
cause a large variance in the penetrating radiation, to the point where
many ray samples are needed to resolve the agregate (i.e., integrated)
behavior.
I hope I didn't misunderstand what you were saying.
Actually, the slat interreflection is significant, but modeling slats in the BRDTfunc directly won't incorporate such behavior, since the surface is flat and therefore doesn't see itself. I have to model the interreflections mathematically, and that's the tricky part. That's the part I think will take a day or two to work out, if I'm able to do it at all.
Date: October 29, 2004 2:31:02 PM PDT
Santiago
