You can use windows power shell to execute Unix command.
Or you can revised the unix command as following:
type points | rtrace -h -ab 1 -I uni.oct | rcalc -e 'SVF=$1;$1=SVF;'
Yongqing Zhao
Changsha Green Building & Energy Saving Technology CO.,LTD
NO.438,Shaoshan Road,Changsha,Hunan,China
Telephone:13574805636
Email:[email protected]
[email protected]
------------------ 原始邮件 ------------------
发件人: "Germán Molina Larrain"<[email protected]>;
发送时间: 2018年4月13日(星期五) 上午9:23
收件人: "Radiance general discussion"<[email protected]>;
主题: Re: [Radiance-general] Any method to calculate sky view factor inRadiance?
Hi Katsuya,
Points should be the name of a file containing the location (Px,Py,Pz) and orientation (Dx,Dy,Dz) of your "illuminance sensors". Something like
0 0 0.8 0 0 1
1 0 0.8 0 0 1
Such case would represent two sensors, one on the position X=0, Y=0, Z=0.8 and one in position X=1, Y=0, Z=0.8... both are looking Up.
I would recommend you to also check tutorials on how the "cat" command works (it is easy, though... it only prints the contents of a file into the terminal) and about piping. That would give you a better understanding on what that command is doing
Best,
El vie., 13 abr. 2018 a las 11:38, Katsuya Obara (<[email protected]>) escribió:
Dear Raphael,
Thank you very much for your answer.
Since I am not familiar with Unix, may I ask you how I should write in Microsoft batch file for following part?
cat points | rtrace -h -ab 1 -I uni.oct | rcalc -e 'SVF=$1;$1=SVF;'
Especially, I could not figure out what points mean.
Thank you.
Katsuya
-----Original Message-----
Sent: Thursday, April 12, 2018 2:38 PM
To: Radiance general discussion
Subject: Re: [Radiance-general] Any method to calculate sky view factor in Radiance?
Hello
A simple approach is to compute the illuminance level under a uniform sky.
First define a uniform sky (uni.rad) like this:
void glow sky_glow
0
0
4 0.318309886 0.318309886 0.318309886 0
sky_glow source sky
0
0
4 0 0 1 180
Note that the radiance value 0.318309886=1/PI This makes the illuminance value computed for an unobstructed horizontal plane equal to 1 and this matches in fact the SVF value!
To compute SVF values for several points, then use rtrace with option -I like this:
oconv uni.rad >uni.oct
where points is a file where calculation points are stored as:
x y z xdir ydir zdir
For instance using these three points you can check that SVF values are well computed as 1 for an horizontal plane and 0.5 for vertical planes:
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Of course SVF values are usually more interesting to compute for scenes containing objects... These should be defined in a scene file and then merged in the octree before doint the SVF calculations:
oconv uni.rad myscene.rad >scene.oct
cat points | rtrace -h -ab 1 -I scene.oct | rcalc -e 'SVF=$1;$1=SVF;'
Hope this will help you!
Raphaël
________________________________
De : Katsuya Obara <[email protected]> Envoyé : jeudi 12 avril 2018 01:54:46 À : [email protected]
Objet : [Radiance-general] Any method to calculate sky view factor in Radiance?
Dear all,
I want to calculate sky view factor.
Trying to find in google, I could not find solid information which I can refer to.
Could anyone tell me what kind of approach I can have to calculate sky view factor?
Thank you.
Katsuya
____________________________________________________________
Electronic mail messages entering and leaving Arup business systems are scanned for viruses and acceptability of content
Radiance-general mailing list
[email protected]
https://secure-web.cisco.com/1Yc5p1jP-sS9GSQOhea6eAvW2j3Mv6gjSilmNn0jJhXvvKTjGAYYE7a2pID0EaTYngTw7vjB6lGhdqxL-dUpmViFpZnymqVpJzYUn27CZNVeNFHbRwlX8Wl6KmmIvNSOGZOFQGJM9zLT0jaORSNdNOgyQ_9j_vagh8pBtQwEDEnW9ltvRUpbDylNJEeU8Hz4FkXlbpdak2LtUJZpjXE7YX2rbe2ngiLG1qD-koTRWavtRn1oW3SLOdY1A8fDRybYd/https%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-general
[email protected]
https://www.radiance-online.org/mailman/listinfo/radiance-general
