Any method to calculate sky view factor in Radiance?
Dear all,
I want to calculate sky view factor.
Trying to find in google, I could not find solid information which I can refer to.
Could anyone tell me what kind of approach I can have to calculate sky view factor?
Thank you.
Katsuya
systems are scanned for viruses and acceptability of content
Hello
A simple approach is to compute the illuminance level under a uniform sky.
First define a uniform sky (uni.rad) like this:
void glow sky_glow
4 0.318309886 0.318309886 0.318309886 0
sky_glow source sky
4 0 0 1 180
Note that the radiance value 0.318309886=1/PI
This makes the illuminance value computed for an unobstructed horizontal plane equal to 1 and this matches in fact the SVF value!
To compute SVF values for several points, then use rtrace with option -I like this:
oconv uni.rad >uni.oct
cat points | rtrace -h -ab 1 -I uni.oct | rcalc -e 'SVF=$1;$1=SVF;'
where points is a file where calculation points are stored as:
x y z xdir ydir zdir
For instance using these three points you can check that SVF values are well computed as 1 for an horizontal plane and 0.5 for vertical planes:
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Of course SVF values are usually more interesting to compute for scenes containing objects... These should be defined in a scene file and then merged in the octree before doint the SVF calculations:
oconv uni.rad myscene.rad >scene.oct
cat points | rtrace -h -ab 1 -I scene.oct | rcalc -e 'SVF=$1;$1=SVF;'
Hope this will help you!
Raphaël
De : Katsuya Obara <[email protected]>
Envoyé : jeudi 12 avril 2018 01:54:46
À : [email protected]
Objet : [Radiance-general] Any method to calculate sky view factor in Radiance?
Dear all,
Thank you.
Katsuya
Dear Raphael,
Thank you very much for your answer.
Since I am not familiar with Unix, may I ask you how I should write in Microsoft batch file for following part?
Especially, I could not figure out what points mean.
Thank you.
Katsuya
Sent: Thursday, April 12, 2018 2:38 PM
Subject: Re: [Radiance-general] Any method to calculate sky view factor in Radiance?
Hello
void glow sky_glow
sky_glow source sky
4 0 0 1 180
Note that the radiance value 0.318309886=1/PI This makes the illuminance value computed for an unobstructed horizontal plane equal to 1 and this matches in fact the SVF value!
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Raphaël
De : Katsuya Obara <[email protected]> Envoyé : jeudi 12 avril 2018 01:54:46 À : [email protected]
Dear all,
Thank you.
Katsuya
Electronic mail messages entering and leaving Arup business systems are scanned for viruses and acceptability of content
https://secure-web.cisco.com/1Yc5p1jP-sS9GSQOhea6eAvW2j3Mv6gjSilmNn0jJhXvvKTjGAYYE7a2pID0EaTYngTw7vjB6lGhdqxL-dUpmViFpZnymqVpJzYUn27CZNVeNFHbRwlX8Wl6KmmIvNSOGZOFQGJM9zLT0jaORSNdNOgyQ_9j_vagh8pBtQwEDEnW9ltvRUpbDylNJEeU8Hz4FkXlbpdak2LtUJZpjXE7YX2rbe2ngiLG1qD-koTRWavtRn1oW3SLOdY1A8fDRybYd/https%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-general
Hi Katsuya,
*Points *should be the name of a file containing the location (Px,Py,Pz)
and orientation (Dx,Dy,Dz) of your "illuminance sensors". Something like
0 0 0.8 0 0 1
1 0 0.8 0 0 1
Such case would represent two sensors, one on the position X=0, Y=0, Z=0.8
and one in position X=1, Y=0, Z=0.8... both are looking Up.
I would recommend you to also check tutorials on how the "cat" command
works (it is easy, though... it only prints the contents of a file into the
terminal) and about piping. That would give you a better understanding on
what that command is doing
El vie., 13 abr. 2018 a las 11:38, Katsuya Obara (<[email protected]>) escribió:
Dear Raphael,
Thank you.
Katsuya
Radiance?
Hello
void glow sky_glow
sky_glow source sky
4 0 0 1 180
like this:
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Raphaël
Radiance?
Dear all,
refer to.
view factor?
Thank you.
Katsuya
Also, substitute the ‘type’ command for ‘cat’ if you’re on Windows. At least back in the day, that was the only substitute. Maybe on newer Windows systems there’s a cat available.(?)
Reply-To: Radiance discussion <[email protected]>
Date: Thursday, April 12, 2018 at 7:27 PM
Hi Katsuya,
Points should be the name of a file containing the location (Px,Py,Pz) and orientation (Dx,Dy,Dz) of your "illuminance sensors". Something like
0 0 0.8 0 0 1
1 0 0.8 0 0 1
Such case would represent two sensors, one on the position X=0, Y=0, Z=0.8 and one in position X=1, Y=0, Z=0.8... both are looking Up.
I would recommend you to also check tutorials on how the "cat" command works (it is easy, though... it only prints the contents of a file into the terminal) and about piping. That would give you a better understanding on what that command is doing
El vie., 13 abr. 2018 a las 11:38, Katsuya Obara (<[email protected]<mailto:[email protected]>>) escribió:
Dear Raphael,
Thank you.
Katsuya
From: Compagnon Raphaël [mailto:[email protected]<mailto:[email protected]>]
Hello
void glow sky_glow
sky_glow source sky
4 0 0 1 180
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Raphaël
De : Katsuya Obara <[email protected]<mailto:[email protected]>> Envoyé : jeudi 12 avril 2018 01:54:46 À : [email protected]<mailto:[email protected]>
Dear all,
Thank you.
Katsuya
https://secure-web.cisco.com/1Yc5p1jP-sS9GSQOhea6eAvW2j3Mv6gjSilmNn0jJhXvvKTjGAYYE7a2pID0EaTYngTw7vjB6lGhdqxL-dUpmViFpZnymqVpJzYUn27CZNVeNFHbRwlX8Wl6KmmIvNSOGZOFQGJM9zLT0jaORSNdNOgyQ_9j_vagh8pBtQwEDEnW9ltvRUpbDylNJEeU8Hz4FkXlbpdak2LtUJZpjXE7YX2rbe2ngiLG1qD-koTRWavtRn1oW3SLOdY1A8fDRybYd/https%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-general<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsecure-web.cisco.com%2F1Yc5p1jP-sS9GSQOhea6eAvW2j3Mv6gjSilmNn0jJhXvvKTjGAYYE7a2pID0EaTYngTw7vjB6lGhdqxL-dUpmViFpZnymqVpJzYUn27CZNVeNFHbRwlX8Wl6KmmIvNSOGZOFQGJM9zLT0jaORSNdNOgyQ_9j_vagh8pBtQwEDEnW9ltvRUpbDylNJEeU8Hz4FkXlbpdak2LtUJZpjXE7YX2rbe2ngiLG1qD-koTRWavtRn1oW3SLOdY1A8fDRybYd%2Fhttps%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-general&data=02|01|robert.guglielmetti%40nrel.gov|e466da7dcd824786f13008d5a0ddc34c|a0f29d7e28cd4f5484427885aee7c080|0|1|636591796701331664&sdata=%2BevDEksEeRnjYHgrFfe%2BbLlzC%2BG2UllOInGYvfg4sdI%3D&reserved=0>
https://www.radiance-online.org/mailman/listinfo/radiance-general<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.radiance-online.org%2Fmailman%2Flistinfo%2Fradiance-general&data=02|01|robert.guglielmetti%40nrel.gov|e466da7dcd824786f13008d5a0ddc34c|a0f29d7e28cd4f5484427885aee7c080|0|1|636591796701331664&sdata=%2BZONmQ0j%2BLGuIAof26zVWP25xseEzw%2B6%2F3Byy8jGtlc%3D&reserved=0>
Hi Katsuya
Yes German's explanation about the content of the point file is right.
If you plan to use Radiance extensively, I really advise you to start using it on a Unix/Linux system for instance by installing a Linux virtual machine on your PC (I am personally using a Ubuntu Linux system running in VirtualBox https://www.virtualbox.org). I am sure you will never regret the time you will have to spend just for learning the basics of a Unix/Linux system...
Raphaël
De : Germán Molina Larrain <[email protected]>
Envoyé : vendredi 13 avril 2018 03:23:11
À : Radiance general discussion
Objet : Re: [Radiance-general] Any method to calculate sky view factor in Radiance?
Hi Katsuya,
0 0 0.8 0 0 1
1 0 0.8 0 0 1
Dear Raphael,
Thank you.
Katsuya
Hello
void glow sky_glow
sky_glow source sky
4 0 0 1 180
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Raphaël
Dear all,
Thank you.
Katsuya
You can use windows power shell to execute Unix command.
Or you can revised the unix command as following:
type points | rtrace -h -ab 1 -I uni.oct | rcalc -e 'SVF=$1;$1=SVF;'
Yongqing Zhao
Changsha Green Building & Energy Saving Technology CO.,LTD
NO.438,Shaoshan Road,Changsha,Hunan,China
Telephone:13574805636
Email:[email protected]
------------------ 原始邮件 ------------------
发件人: "Germán Molina Larrain"<[email protected]>;
发送时间: 2018年4月13日(星期五) 上午9:23
收件人: "Radiance general discussion"<[email protected]>;
主题: Re: [Radiance-general] Any method to calculate sky view factor inRadiance?
Hi Katsuya,
0 0 0.8 0 0 1
1 0 0.8 0 0 1
Dear Raphael,
Thank you.
Katsuya
Hello
void glow sky_glow
sky_glow source sky
4 0 0 1 180
0 0 0 0 0 1
0 0 0 0 1 0
0 0 0 1 0 0
Raphaël
Dear all,
Thank you.
Katsuya
