Hello community,
I have a problem that the luminance of the central spotlight on the ceiling (you may not even know it exists in the attached image) disappears when rendering with Radiance such as the following image:
The spotlights installed in the room, with which are 19 degrees (center of the room) and 31 degrees (right), are converted to RAD using the following commands and rendered;
%ies2rad -t default -dm/1000 -o ies/19 -c *** -m 0.06 ies/19.txt
%xform -t 1500 1500 2250 ies/19.rad > m_light/19.rad
%ies2rad -t default -dm/1000 -o ies/31 -c *** -m 0.1 ies/31.txt
%xform -t 2250 1500 2250 ies/31.rad > m_light/31.rad
%oconv materials.rad room.rad m_light/19.rad m_light/31.rad > room.oct
%rpict -vp *** -vd *** -vv 120 -vh 120 -vu 0 0 1 -ab 2 -aa .5 -ar 64 -ad 64 -as 32 -x 800 -y 800 -t 10 room.oct > room.hdr
19.txt and 31.txt mean ies data downloaded by a manufacturer.What kind of operation is required to output correctly as the light source like the right one?
