Ambient File and BSDF
I’m trying to model woven shades using a BSDF from the CGDB. To get better looking and more accurate results I am using a BRDF as the standing geometry that is based off of a .cal file that greg wrote for metal grating: https://www.dropbox.com/s/bzo9apzcl4ioika/rollershade.cal?dl=0
when I apply this material to geometry it behaves as expected and cuts off the direct relative to the angle of incidence (which I hope explains this funny test scene I’m using)
image of BRDF shades: https://www.dropbox.com/s/tlcqqij9rjng5s6/BRDF_mar21_test_test_fc.jpg?dl=0
But this does not give me accurate diffuse values. So I then put the BRDF as a proxy for the BSDF and get an image like this:
My question arises when I look at image without proxy geometry for the BSDF.
First rendered with multiple processes: https://www.dropbox.com/s/1cw56kwevnx9ajt/mt_BSDF_mar21_test_test_fc.jpg?dl=0
And run on a single processor: https://www.dropbox.com/s/pm5q8ikh6kgwh6f/BSDF_mar21_test_test_fc.jpg?dl=0
or to view it more starkly, the difference between the BSDF alone and with proxy:
bsdf - proxy: https://www.dropbox.com/s/hf2vy2wfpss7gr0/BSDFboth_fc.jpg?dl=0
proxy - bsdf: https://www.dropbox.com/s/di8duoz2gob0ams/bothBSDF_fc.jpg?dl=0
There is a major change in the ambient values once the rendering gets to the window (which is why the band is horizontal in the single process run and vertical in the multiple process run. I ran these using rad so there is an overture calculation. Anyone have an idea as to what is going on?
Stephen Wasilewski
LOISOS + UBBELOHDE
Alameda, CA 94501 USA
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
Hi Stephen,
What is outside your space? Did you model a ground plane? What rendering parameters is rad handing to rpict and rpiece?
My best guess is that when your rays get to the upper sill of the window, they bounce outside and create ambient values that then leak some energy into your scene interior. It shouldn't really happen with the latest release, so if that's what is going on, then there may be a bug in the new interreflection code.
If you want to send me your complete model, etc. offline, I can try to have a look at it tomorrow.
Subject: [Radiance-general] Ambient File and BSDF
Date: September 11, 2014 6:57:27 PM PDT
I’m trying to model woven shades using a BSDF from the CGDB. To get better looking and more accurate results I am using a BRDF as the standing geometry that is based off of a .cal file that greg wrote for metal grating: Dropbox - Error - Simplify your life
image of BRDF shades: Dropbox - Error - Simplify your life
First rendered with multiple processes: Dropbox - Error - Simplify your life
And run on a single processor: Dropbox - Error - Simplify your life
bsdf - proxy: Dropbox - Error - Simplify your life
proxy - bsdf: Dropbox - Error - Simplify your life
Stephen Wasilewski
LOISOS + UBBELOHDE
510 521 3800 VOICE
510 521 3820 FAX
www.coolshadow.com
Hi Stephen,
This turned out to be a subtle problem that I've seen on rare occasions in the past related to the direct approximation in Radiance. If you set -dt 0, the issue goes away (and accuracy improves). In 1990 or so, I implemented an optimization in Radiance for many light sources that comes up with a statistical estimate of direct illumination. It usually doesn't cause any issues, but in scenes with one or two sources and a lot of indirect illumination, it can result in systematic errors when you compute a scanline at a time.
In your scene, the indirect rays are all inside, and never see the sun directly. (Even the rays that hit the window count as indirect.) Thus, the statistical estimate of hitting the sun is very small or zero. Once the rendering reaches the window, however, it treats it like a trans and computes direct rays from the opposite side, with nearly 100% of hitting the sun. This causes a sudden shift in the statistical estimate, so that subsequent rays that forgo testing get this higher estimate.
As a fix, I've changed the code so with 4 or fewer sources, shadow rays will be sent every time, even when indirect dominates. This should eliminate this problem and others like it. I wish I had thought of this fix a long time ago....
Subject: Re: [Radiance-general] Ambient File and BSDF
Date: September 11, 2014 8:01:19 PM PDT
Hi Stephen,
Stephen Wasilewski
LOISOS + UBBELOHDE
