Hi Greg and Iebele,
I have a comment and a question on this.
First, Iebele, I have also just gotten a 3D xfrog tree. FYI, it is possible to generate an obj, convert to a radiance mesh and use Local u,v coordinate mapping to get the leaf and bark materials to apply. I have a tree right now that basically has a few materials defined for it:
1. bark with colorpict modifier
2. leaf with colorpict modifier
3. leaf-mix mixpict - this uses an alpha version of the leaf to mix
between void (ie where the alpha is black) and the leaf material (2)
The question for Greg is this, to exclude the leaves from the ambient calculation what needs to be listed in the exclude file the "leaf" material and/or the "leaf-mix" material?
Iebele, the one thing to note is that the obj file that comes out of xfrog does not play well with obj2mesh or obj2rad. Thus I have to bring it into PolyTrans and re-export as an obj to get a file that radiance is happy with.
Gregory J. Ward wrote:
Hello Iebele,
Since you have too many materials in your "ambient exclude" list, you're best hope is to switch to an "ambient include" list, instead. Create a file listing all of the materials, hopefully not xform'ed and duplicated like your leaves, that you would like to include in the interreflection calculation. These can be put in a file and incorporated with a single -aI option.
The other alternative is to switch off the irradiance cache using -aa 0 and assign other parameters to make the problem tractable over all surfaces.
Date: April 2, 2007 9:08:03 AM PDTHi,
I have a complex scene in which I use instances which I want to exclude from ambient calculation.
The problem is that I use !xform ..... with file A that include materials to create another file B that is later used as an instance.
I need the materials in file A excluded from ambient calculation.
The exclusion does not seem to work in my case, which makes the rendering times enormous ( lightyear - 0.01 % progress per hour in the picturel, very very much rays )Any help is most welcome.
-Iebele
# Jack de Valpine
