Hi Jeff,
If you add the line
opt = filename.opt
to your rad file and run rad, it will generate
an .opt file that lists all settings for that rendering.
If you want to test out the settigs resulting from
various qualities, make sure not to override them
manually (do not put INDIRECT = or
render = -ab -av etc. in your rad file)
Karen
______________________________________
Karen Carrier
M.ARCH
UC Berkeley
Sorry everybody for the messed up message.
Being new to posting messages I didn't realize
that I needed to use plain text e-mails.
It should have read:
Hi Jeff,
If you add the line
opt= filename.opt
If you want to test out the settings resulting from
manually (do not put INDIRECT= or
render= -ab -av etc. in your rad file)
Karen
Karen Carrier
M.ARCH
UC Berkeley
