Access to outgoing radiance at polyhedra level
Hi Olivier,
The simplest method is to use rtrace. You can separate your polygons by name with:
  vwrays [resolution & view options] | rtrace -h -osv scene.oct | sort > surfaces.txt
You should get a selection of radiance values for each surface based on the selected view. If you want orthonormal values for _every_ polygon, not just those visible from one perspective, more sophisticated methods are needed. You would have to read in the scene file and generate a custom view for each polygon. It can be done, but it might require some scripting/programming to accomplish it.
P.S. If you want irradiance/illuminance values rather than radiance/luminance, use the rtrace -i option.
Date: November 12, 2013 5:36:30 AM PST
Hi Everyone,
I am using Radiance to render objects using realistic lighting conditions.
The objects I use are represented as triangulated polyhedra. Currently I'm accessing
the radiance outgoing from the objects in a scene using rendered images (rpict and then pfilt)
of the scene (with no information anymore on each single triangle).
I am wondering whether it is possible to have access to the
radiance outgoing from each triangle directly (as a list of values, one for each triangle
for example)?
I'm running minGW radiance in windows (with a Matlab wrapper), but could
switch to Linux if required.
Best wishes,
Olivier---
Dr Olivier Penacchio---
School of Psychology & Neuroscience
St Mary's Quad
South Street
St Andrews
Fife
KY16 9JP
Scotland, United Kingdom
Tel: +44 (0) 1334 462099
Fax:+44 (0) 1334 463042
Email:[email protected]
