wxfalsecolor v0.50 released - contains important bug fix
A new version of wxfalsecolor.exe is available.
priority: *HIGH*
All users should update to this version.
This version fixes a bug which can lead to wrong spot values being displayed
for falsecolor images.
You can download the new version via the following link:
http://pyrat.googlecode.com/files/wxfalsecolor.exe
major changes:
This version adds command line support. Falsecolor2 options and new debug
options ('-v' and '-d') can now be given as command line arguments following
the falsecolor2 argument convention.
It also includes a new configuration file parser which will allow future
versions to read configuration options set by the user. This version will
create a configuration file in the user's %APPDATA% (Windows) or $HOME
directory on the first startup.
further changes:
* fixed a problem with the status bar that caused an error message to pop up
on close
* changed the start sequence so that the interface appears now before data
is loaded or a falsecolor conversion starts
* new automatic and manual update checks
* logging is now done via the Python logging module
