# Work in progress - living room
**URL:** <https://discourse.radiance-online.org/t/work-in-progress-living-room/4669>\
**Category:** radiance-general\
**Created:** [September 16, 2018, 1:47pm UTC](https://discourse.radiance-online.org/t/work-in-progress-living-room/4669 "2018-09-16T13:47:20Z")\
**Posts on this page:** 1\
**Showing post:** 19
<div class="post-metadata">
**Author:** ![Dion\_Moult](https://discourse.radiance-online.org/user_avatar/discourse.radiance-online.org/dion_moult/32/517_2.png) [@Dion\_Moult](https://discourse.radiance-online.org/u/Dion_Moult)\
**Post date:** [January 4, 2019, 11:59pm UTC](https://discourse.radiance-online.org/t/work-in-progress-living-room/4669/19 "2019-01-04T23:59:35Z")
</div>
Another update! I’ve started experimenting with turning this into a VR scene. I’ve been asking [questions about VR panoramas in Radiance](https://discourse.radiance-online.org/t/can-radiance-render-out-a-360-equirectangular-panoramic/4784/8), and here is my first attempt. You can [view it with WebVR on your browser here](https://thinkmoult.com/vr/). If you view it on your phone you can get the split view, and if you have a Cardboard VR, you can put on the goggles and check it out!
The WebVR is built on A-Frame, which is a wrapper to ThreeJS, which is all open-source, self-hosted, and only a few lines of code to implement online.
Here’s a screenshot for those who like a visual preview before clicking that link 🙂
 ![Screenshot_20190105-104420](https://discourse.radiance-online.org/uploads/default/original/1X/f7d7a470b99865f01c96d43f6365855fd2cdb037.jpeg)
And yes, my living room does indeed having an entire back wall with a green colour!
There are still many issues with it. The current technique used is a cubemap, filtered with `pcond` using a combined histogram. The list of issues include:
- Low resolution. The resolution is currently 1024x1024, but this is the raw dimension, not the pfilt dimension so it needs to be much larger! I may need to render the raw at 3072 then scale down.
- Cubemap edges slightly visible
- Strange light leaks
- Scene incomplete, you can see the end of the fence and no ground where the planter bed is. I never bothered modeling that part before because it wasn’t visible in the perspective.
![2019-01-05-105206_983x829_scrot](https://discourse.radiance-online.org/uploads/default/original/1X/72c80611ac085a9b41c9dd16524ea060ac4a85fa.png)
In addition, there are these issues:
- Blotchy rendering, perhaps just a condition of using a low-resolution render
- My arrayed wall does not tile perfectly and so the edges appear black
- The seam of where the tiled stucco wall ends and the simplified flat wall starts is very obvious
![2019-01-05-105150_855x652_scrot](https://discourse.radiance-online.org/uploads/default/original/1X/edc5afa4eb0f304d0b372bfad19ca1cfaa8f4354.png)
_[View the full topic](https://discourse.radiance-online.org/t/work-in-progress-living-room/4669)._
