WINDOW 7.3 shut down with BSDF of Venetian blind created with genBSDF
Hello Everyone,
I have already created a BSDF project which contains a Venetian blind with
a genBSDF,in which I enter the geometry, the material and the glazing. To
do this I have used the next command (in addition,I attached the respective
files)
genBSDF -n 8 materials.mat glazing.rad Layer0.rad > Case1.xml
Apparently,It worked right since I can see it in BSDF Viewer.
However , the problem happen when I connect this BSDF with the window which
contains WINDOW 7.3 software.So, when I try to add a shading since XML
file, the program shut down.
I have looked over each step but I dont know where can be the mistake.Do
you have any idea about this problem or what is happening?
Thanks you in advance,
King regards,
Daniel
Daniel Uribe Cáceres
Estudiante de Ingeniería Civil
Diploma en Ingeniería Estructural
Pontificia Universidad Católica de Chile
