Hello all,
I am completly new to Radiance and I am trying to use it on my AutoCAD,
2007, here is the catch.
I didn't find enough information to build a workflow that allows me to
process daylighting simulation on a windows based machine.
Do I have many, open source or not, options to go from the drawning to the
light simulation?
Valère Paupelin-Huchard
I think you should have a look to blender + brad from master Francesco
G.
around here:
http://www.bozzograo.net/radiance/index.php?module=photoshare&func=viewallfolders
From: [email protected] [mailto:[email protected]] On Behalf Of Valère Paupelin-Huchard
Sent: 16 August 2007 00:57
To: [email protected]
Subject: [Radiance-general] Win Users and Radiance
Hello all,
I am completly new to Radiance and I am trying to use it on my AutoCAD, 2007, here is the catch.
I didn't find enough information to build a workflow that allows me to process daylighting simulation on a windows based machine.
Do I have many, open source or not, options to go from the drawning to the light simulation?
Giulio Antonutto wrote:
I think you should have a look to blender + brad from master Francesco J
G.
If you're committed to using AutoCAD as your modeling program, you can also check out Georg Mischler's AutoCAD export utilities. They only work on older versions of AutoCAD, though:
http://www.schorsch.com/download/radout/
http://www.schorsch.com/download/torad/
Another option you have is the dxf2rad utility, which is part of the Radiance suite of tools. If you use ACIS solids, you can use 3DSOUT (in AutoCAD) to export a polygonal model, then bring it back in with 3DSIN, then back out with DXFOUT, then use dxf2rad to convert the geometry to a radiance scene description. A bit circuitous, but it would work.
Good luck and have fun!
- Rob Guglielmetti
I use the circuitous method Rob mentioned. Also, you can run Cygwin on your Win machine in order to have Unix and a way to run radiance.
Mark
Hi Valere,
I think you'd try ECOTECT+RADTOOLS+RADIANCE for windows
1- model geometry in ECOTECT, set location, materials properties
2-export for RADTOOL, set sky, resolution, etc analysis configuration
3-run simulations
4-analyse in IMAGE VIEWER
it's very easy and fast.
You dont have even to buy ECOTECT just use it as a interface to RADIANCE!!!!
see more details in http://squ1.com/projects/freeware
regards,
evangelos
PS. you have to download the RADIANCE 3.7 binaries compiled for windows,
from FRANCESCO ANSELMO site
(here<http://www.bozzograo.net/radiance/modules.php?op=modload&name=Downloads&file=index&req=getit&lid=12>
light simulation?
