Where does bgraph look for .plt files?
Hello everyone!
I found a similar discussion on this link:
http://www.radiance-online.org/pipermail/radiance-dev/2013-December/001383.html
But still couldn't figure out. What could be the reason?
*When I try bgraph command, I get an error that .plt file is not found.*
bgraph lux.plt | x11meta
include=line.plt
bgraph: lux.plt: File not found: line.plt
*Here is the lux.plt file:*
include=line.plt
title="Working Plane Illuminance"
xlabel="Distance from Window"
ylabel="Illuminance [lux]"
Adata=lux.csv
Acolor=2
*line.plt file is present in:*
/usr/share/radiance/meta
*RAYPATH is set to:*
echo $RAYPATH
.:/usr/share/radiance:
*When I copied the line.plt file to working directory, the error is:*
include=line.plt
*When I gave absolute path of line.plt file in lux.plt file, the error is:*
bgraph: Cannot open: /usr/share/radiance/meta/line.plt
*Radiance version is:*
RADIANCE 4R1+20120125-1+b1 (Debian package) 32bit
So the question arises, Where does bgraph look for .plt files?
Thank you!
Vaib
You probably need to set the $MDIR environment variable in your .bashrc (or other) startup script. Some default directory location gets compiled in, but it must not agree with your particular installation location. This variable is separate from the $RAYPATH setting, but similar. It is the only other variable you need set in Radiance, as these plotting tools predate any of the others.
Once you find where these files are located (try "/usr/share/radiance/meta" for starters), set your environment variable like so:
  export MDIR=/usr/share/radiance/meta/
The trailing '/' is necessary in this case.
Good luck!
Subject: [Radiance-general] Where does bgraph look for .plt files?
Date: April 15, 2014 9:16:28 AM PDT
Hello everyone!
include=line.plt
include=line.plt
Adata=lux.csv
Acolor=2
RAYPATH is set to:
echo $RAYPATH
include=line.plt
Thank you!
Vaib
Thank you Dr.Greg,
Still it remains same.
echo $MDIR
include=line.plt
Vaib
like so:
Good luck!
*Subject: *[Radiance-general] Where does bgraph look for .plt files?
*Date: *April 15, 2014 9:16:28 AM PDT
Hello everyone!
include=line.plt
include=line.plt
Adata=lux.csv
Acolor=2
echo $RAYPATH
include=line.plt
Thank you!
Vaib
As I *said*, you need to determine where the files are living on your system. I don't know. That's why there's an environment variable. You need to FIRST find the file "line.plt" on your system, THEN set the $MDIR variable to that location. Simple.
Subject: Re: [Radiance-general] Where does bgraph look for .plt files?
Date: April 15, 2014 10:20:06 AM PDT
Thank you Dr.Greg,
echo $MDIR
include=line.plt
Vaib
Good luck!
Hello everyone!
include=line.plt
include=line.plt
Adata=lux.csv
Acolor=2
RAYPATH is set to:
echo $RAYPATH
include=line.plt
Thank you!
Vaib
Sorry if I missed to mention, all the .plt files are present at
only, and I have set the MDIR environment variable (in both .profile, and
.bashrc) to the same path. I just crosschecked again. May be there is
something not working on my system. Or not a good day today. Thank you!
Vaib
*Subject: *Re: [Radiance-general] Where does bgraph look for .plt files?
*Date: *April 15, 2014 10:20:06 AM PDT
Thank you Dr.Greg,
echo $MDIR
include=line.plt
Vaib
like so:
Good luck!
Hello everyone!
include=line.plt
include=line.plt
Adata=lux.csv
Acolor=2
echo $RAYPATH
include=line.plt
is:*
Thank you!
Vaib
That is very strange in that case. What happens when you run the following:
  csh -f -c 'ls -l ${MDIR}line.plt'
You should see something like:
  -rw-r--r-- 1 gward admin 728 Feb 13 1990 /usr/share/radiance/meta/line.plt
...only with your user name, obviously. Make sure the file is readable. The contents of the file should be:
# This file defines a standard line plot,
# where a curve is represented by lines
# connecting each point.
include = standard.plt # standard definitions
lthick = 2 # line thickness
(...and so on...)
I can't think what else might be wrong.
Date: April 15, 2014 11:19:31 AM PDT
Sorry if I missed to mention, all the .plt files are present at /usr/share/radiance/meta/ only, and I have set the MDIR environment variable (in both .profile, and .bashrc) to the same path. I just crosschecked again. May be there is something not working on my system. Or not a good day today. Thank you!
Vaib
Thank you Dr.Greg,
echo $MDIR
include=line.plt
Vaib
Good luck!
Hello everyone!
include=line.plt
include=line.plt
Adata=lux.csv
Acolor=2
RAYPATH is set to:
echo $RAYPATH
include=line.plt
Thank you!
Vaib
I very much appreciate your efforts Sir. Everything on my system seems the
same as you wrote.
-rw-r--r-- 1 root root 728 Jan 25 2012 /usr/share/radiance/meta/line.plt
/usr/share/radiance/meta/line.plt file's first few line are:
# Curve defaults:
Athick = lthick # line thickness for A
Alintype = 1 # line type for A
Asymsize = 0 # symbol radius for A
Acolor = 4 # color for A
Thank you.
Vaib
following:
(...and so on...)
*Date: *April 15, 2014 11:19:31 AM PDT
Vaib
Thank you Dr.Greg,
echo $MDIR
include=line.plt
Vaib
like so:
Good luck!
Hello everyone!
include=line.plt
include=line.plt
Adata=lux.csv
Acolor=2
echo $RAYPATH
include=line.plt
is:*
Thank you!
Vaib
