Thanks Raphael and Jan,
I assume Meteonorm would be the best source of information for these kind
of cases. However; is that data representative enough to use it for design
just as if it were a measured data? Should we take anything special into
account?
THANKS!
2014-06-20 10:42 GMT-04:00 Wienold Jan <[email protected]>:
Hi German,
in those cases, we usually use "Meteonorm" to generate a specific weather
data set. It interpolates from the closest weather stations and they have
a huge data basis. For Chile I would guess around 20 (just rough estimation
looking at the map).
But it is important to know that the hourly irradiation data is generated
stochastically from the monthly data (from the weather stations), so
Meteonorm does not use hourly measured data as basis.So in some kind you get a artificial weather data set, based on the
interpolation of real measurements.
It includes also temperature and humidity, all you need for thermal
simulation, too.The output can be chosen in different formats, also epw.
cheers,
Jan
*Sent:* Friday, June 20, 2014 3:20 PM
*To:* Radiance general discussion
*Subject:* [Radiance-general] What to do when no Weather File is
available?Dear Everyone,
This question may be slightly out of the scope of this list; however, I
guess people here might be able to answer it.I have been wondering, during the last few months, what do people do
when there is no available Weather File for a certain location.An example is my country: there are 5 EPW available for Chile and one of
them is for Easter Island. For those who do not know, Chile is a very long
country, with many climates and latitudes. For what I remember from my
undergraduate classes, solar radiation can be obtained from monthly data.
Can we do anything for relative humidity and temperature?Is there any other source of weather files that can be used? How about
Stocastic Weather Files generators?--
*Germán Molina L.*
Ingeniero Trainee
Hunter Douglas Chile S.A.
Celular +569 89224445*Nota de Confidencialidad:* Este mensaje incluído los archivos adjuntos
son confidenciales y pueden contener informacion privilegiada protegida por
ley. Si Ud. no es el destinatario, deberia abstenerse de copiarlo,
distribuirlo, divulgarlo o usar la informacion contenida. Por favor, avise
inmediatamente al emisor y borre este mensaje de su sistema. Los mensajes
electronicos son susceptibles de ser cambiados, infectados o adulterados
sin autorizacion. No asumimos responsabilidad alguna por ninguna clase de
cambios o sus consecuencias. Usted debe estar informado que la compania
puede hacer un seguimiento de sus mensajes electronicos y su contenido,
gracias.*Confidentiality Notice:* The information contained in this email
message, including any attachment, is confidential and is intended only for
the person or entity to which it is addressed. If you are neither the
intended recipient nor the employee or agent responsible for delivering
this message to the intended recipient, you are hereby notified that you
may not review, retransmit, convert to hard copy, copy, use or distribute
this email message or any attachments to it. If you have received this
email in error, please contact the sender immediately and delete this
message from any computer or other data bank, Thank you.A informação transmitida é confidencial e para conhecimento exclusivo do
destinatário. Sua utilização, não autorizada, constitui crime passível de
prisão. Todas as precauções possíveis foram tomadas para garantir que este
e-mail não contenha vírus. Uma vez que nossa empresa não pode assumir
responsabilidade por nenhuma perda ou dano causado por este e-mail ou de
seus anexos, recomendamos que o destinatário utilize seus procedimentos de
antivírus antes de qualquer uso._______________________________________________
Radiance-general mailing list
[email protected]
http://www.radiance-online.org/mailman/listinfo/radiance-general
*Germán Molina L.*
Ingeniero Trainee
*Nota de Confidencialidad:* Este mensaje incluído los archivos adjuntos son
gracias.
*Confidentiality Notice:* The information contained in this email message,
including any attachment, is confidential and is intended only for the
person or entity to which it is addressed. If you are neither the intended
recipient nor the employee or agent responsible for delivering this message
to the intended recipient, you are hereby notified that you may not review,
retransmit, convert to hard copy, copy, use or distribute this email
message or any attachments to it. If you have received this email in error,
please contact the sender immediately and delete this message from any
