Yes, you understand my email correctly.
I have just find that the material is probably not only the reason. I have
the window split into parts parts and only BSDF for bottom part (down)
generate this warning. Here is the command for both parts of window, and
only difference is the bounding box, which I assume is correct.
### this one produce the warning
genBSDF -c 1000 -n 8 -r @BSDFparameters.opt +forward -backward -geom -dim 0
1.98 0 1.13 -0.01 0 \
geometry/materialNew.mat geometry/30_geometry.rad >
results/BSDFdown_30_new.xml
1.98 1.13 2.26 -0.01 0 \
results/BSDFup_30_new.xml
I am actually using dctimestepcpu instead of dctimestep because it is much
faster, but I guess it is updated too.
I have got this message before but with dctimestep and not dctimestepcpu. I
fixed that in that time but I am not sure what was wrong, I guess it was
something with wrong geometry and there were many more dirrection which
collected higher %.
My question could be also understand as: Would this error also appear when
there is light concentration in one spot after it is reflected?
Thank you
David
On 23 May 2011 08:32, Greg Ward <[email protected]> wrote:
Hi David,
If I understand your e-mail correctly, you are seeing this error using the
NEW material, not the OLD one.I cannot reproduce your error. I assume from your earlier e-mails that you
are using the latest HEAD of Radiance. You should make sure that everything
is up-to-date and try it again. In particular, we fixed some problems last
December in the normalization of results. The dctimestep program has also
been improved and corrected.-Greg
*Date: *May 23, 2011 7:51:13 AM PDT
*Dear Radiance users,
I am getting warning messagewarning - outgoing BSDF direction 142 collects 107.4% of light
when multiplying matrixes by dctimestep. I generated BSDF matrix by
genBSDF.
I guess that I can still use it but is this message saying that it could be
wrong or is it more just like a statement that there is literally more light
coming to direction 142.
I generated more of BSDF matrexis and I kept same geometry and changed only
one material which has higher reflectance. I guess that it can be reason but
I would like to be sure that the BSDF matrix is still reliable.Here is the material description for OLD and NEW (with warning message when
used)
NEW material is generated by "optics2rad"
OLD material is generated by script "glaze" and "optics2glazedb"Thank you very much I very appreciate your help
Davidvoid BRTDfunc OLD
10
sr_frit_r sr_frit_g sr_frit_b
st_frit_r st_frit_g st_frit_b
0 0 0
glaze1.cal
11
0.0564
0.0492
0.051
0.126
0.126
0.126
0.054
0.054
0.054
1 .6void BRTDfunc NEW
10
rR_clear rG_clear rB_clear
0.678*tR_clear 0.655*tG_clear 0.576*tB_clear
0 0 0
window.cal
15 0 0 0 0 0 0 0 0 0
0.267 0.321 0.395
0.24 0.306 0.368_______________________________________________
