I'm trying to create the view_param.cal mentioned in RwR page 328
I think I've typed it exactly as it is in the book, then copy it to
/usr/local/lib/ray/view_param.cal
_______________________________________
{ view_param.cal
Arbitrary aspect ratio:
p = pixel aspect ratio (height/width=input)
h = horizontal view angle (input)
v = vertical view angle (output)
v = 114.6*atan(p*tan(h/114.6))
{ View parameters specific to 35mm film
f = focal length of lens (input)
v35 = vertical view angle -vv (output)
h35 = horizontal view angle 0vh (output)
v35 = 114.6*atan(17/f)
h35 = 114.6*atan(11.5/f)
but I get an error when I try to use it
calc view_param.cal
I get back:
view_param.cal, line 15:
^ ';' expected
What am I missing?
Thanks
Rob F
Hi Rob,
There are a couple of things here.
1. Each line of non-comment code in a cal needs to be terminated with
';' (note comments are enclosed in {} and do not need to be
terminated by ';')
2. Depending on where rayinit.cal is located you may need to do the
following: calc /mypath/ray/rayinit.cal view_param.cal
-Jack de Valpine
{ view_param.cal
but I get an error when I try to use it calc view_param.cal
I get back:
^ ';' expected
What am I missing?
Thanks
Rob F
# John E. de Valpine
I'll remember that!
Many thanks from a scripting noob!
Rob
Sent: 8/3/2004 12:18 PM
Subject: Re: [Radiance-general] view_param.cal
Hi Rob,
with ';' (note comments are enclosed in {} and do not need to be
terminated by ';')
-Jack de Valpine
